Heater By-Pass Valving
What kind of valves do you guys suggest - With a Big Block and A/C - it is so cramped for space - so a few extra bucks on smaller, valves will be worth it.
Any pics or suggestions on locations is greatly appreciated.
I am thinking below the expansion tank have a tee fitting and the a valve before the heater core. On the other side (from the intake) a tee of course for the other side of the crossover by-pass, and below it another valve before the heater core. The 3rd valve would be in the crossover bypass area.
I hope this is understandable. :smash:
[Modified by kaiserbud, 11:00 PM 5/18/2003]
I actually installed a custom valve that doesn't block the flow...it has two input and two output lines so that it routes flow back around to the block and insulates between the heater core and bypass. I suppose it would also be a good idea to put a stop valve to prevent any flow from going through the bypass as well...I may install that this year.
[Modified by Rockn-Roll, 10:56 PM 5/18/2003]
