FlowMaster 50 ???
Old May 19, 2003 | 09:43 AM
mvftw's Avatar
mvftw
Default FlowMaster 50 ???
For all you guys that have Flowmaster 50's, what tips are you using & where did you get them from? I have a '78. I'm having true duals, no cats, & 50's put on this weekend. :D
Old May 19, 2003 | 09:49 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: FlowMaster 50 ??? (mvftw)
How do you like the 50s? I have been thinking of changing mufflers on mine. I have 2 1/2 in. all the way to the stock style mufflers. They sound pretty good while idling and while getting on it but just go away while cruising down the road. I think I am looking for a little more noise.
Old May 19, 2003 | 09:54 AM
mvftw's Avatar
mvftw
Default Re: FlowMaster 50 ??? (Eddie 70)
I'll tell you Saturday afternoon :D . I've been told that the 50's are the way to go, Great sound and last a long time. I'm going with 21/4", I don't have the HP for 21/2".
Old May 19, 2003 | 10:10 AM
pws69's Avatar
pws69
I had stock mufflers also, and they were too quiet. I don't like a LOT of noise (but I do like it to be heard), but wanted the thing to breath so I decided on 2 1/2 into DeltaFlow 50's - the sound is purfect for me!! Nice low rumble at idle, smooth mellow tone at cruise, very healthy and throaty when I summon the demons! I believe the X-Pipe also helped a lot to mellow them out and eliminate the droning.
[Modified by pws69, 10:12 AM 5/19/2003]
Old May 19, 2003 | 11:09 AM
Gordonm's Avatar
Gordonm
Default Re: FlowMaster 50 ??? (pws69)
:iagree: The 50s are perfect for me. I am using the stock 72 tips but they have been modified. I had them remove the 2 inch coupler on the stock tip and weld in a 2 1/2 coupler. You would never know it is not stock.
Old May 19, 2003 | 02:45 PM
isosceles's Avatar
isosceles
Default Re: FlowMaster 50 ??? (Gordonm)
Does anyone know which is louder, Flowmaster 50's or Dynomax super turbo's?
According to the chart on corvettefaq, the Dyno's are supposed to flow a little more (410cfm vs 362)
[Modified by isosceles, 1:47 PM 5/19/2003]
Old May 19, 2003 | 10:55 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Re: FlowMaster 50 ??? (isosceles)
I have Dyno Super Turbos on my 72 with tha base sb 350. Sounds good, but I wish I had put on Flowmasters . . . that muscle car sound is hard to beat. The instaler talked me out of Flowmasters . . .too loud . . .too much interior noise!!
Next time :thumbs:
Old May 19, 2003 | 10:59 PM
PRNDL's Avatar
PRNDL
OK, i have a confession to make... I have a 68 so you probably wouldnt want to use these tips anyway, but i ordered a pair of 2 1/2" round slant cut tips from JC Whitney. They actually would have been great except they start at 2 1/2" and then widen out to 3", which is a bit too wide.... they look a little ricey to me. The stock tips are only 2" :) MJ
To FlowMaster 50 ???
