Correct grease
Old May 19, 2003 | 11:49 AM
69side's Avatar
69side
Default Correct grease
What grease should I use for poly suspension parts ??
Old May 19, 2003 | 12:19 PM
75 Hot One's Avatar
75 Hot One
Default Re: Correct grease (69side)
Regular chassis grease will do. A moly lube is better. I use a spray moly lube which dries and lasts for a long time (depending on driving conditions). Dry powdered graphite (e.g. door lock lubricant) will also work (some poly bushing manufacturers impregnate with graphite-presumably no lube req'd).
