Birdcage rust
Old May 19, 2003 | 12:46 PM
Ray z's Avatar
Ray z
Default Birdcage rust
What is the best way to detect birdcage rust. What areas of birdcage are more prone to rust
Old May 19, 2003 | 01:07 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Default Re: Birdcage rust (Ray z)
Areas to check for rust around the windshield frame (birdcage) would be to remove the exterior stainless trim. You could also remove the interior trim.
Without any disassembly look very carefully around the vin tag area for rust. I'm also told in real bad cases if you place a white cloth on the drivers side floor and open and close the door smartly you will see flakes of rust land on the cloth.
Good luck!!
Old May 19, 2003 | 02:13 PM
'71vert's Avatar
'71vert
Or in my case, I just removed the kickpanel and saw it all piled up in the cavity where a speaker could go. :(
Old May 19, 2003 | 04:28 PM
gq82's Avatar
gq82
Default Re: Birdcage rust ('71vert)
Ouch....not good :nonod:
Old May 19, 2003 | 04:42 PM
stpman's Avatar
stpman
Default Re: Birdcage rust (gq82)
Or in my case I removed the interior trim and found gobs of windshield sealant and no frame left.
Steve :steering:
To Birdcage rust
