Mounting
Old May 20, 2003 | 03:20 PM
Sleper's Avatar
Sleper
Default Mounting
Changing my body mounts to poly. Any tricks or tips? Thanks :cheers:
Old May 20, 2003 | 06:11 PM
Cor6996vette's Avatar
Cor6996vette
Default Re: Mounting (Sleper)
Do a search on body mounting , alot of infor there.
Old May 21, 2003 | 06:50 AM
Sleper's Avatar
Sleper
Did the search and nothing there of intrerst????? :confused:
Old May 21, 2003 | 08:55 AM
jimvette999's Avatar
jimvette999
Do one side at a time and use anti-seaze compound on new or old bolts to facilitate removal the next time...i.e. frame off restoration. Directions that come with parts should be all the info you need. You may want to spray bolts now with penetrating oil to make removal easier this weekend.
Jim
Old May 21, 2003 | 11:59 AM
Cor6996vette
Hi ,
I sent you email of the instruction how to replaced body mounting. Hope this help.
Old May 21, 2003 | 12:09 PM
NHvette's Avatar
NHvette
Default Re: Mounting (myisa69)
If you can easily get the old bolts out - then it should be a breeze.
One side at a time is Ok - but loosen all 8 bolts first.
Getting the old bolts out sux.
very lucky = they come out
so/so = they snap off
unlucky = too rusted to get a wrench on
My 75 had all snapped/spun/or rotted away.
My 70 had them all come out with a 1/2" ratchet !!!
Good luck !!
:seeya
To Mounting
