Smart struts installed...
Old May 20, 2003 | 09:07 PM
Shark Racer's Avatar
Shark Racer
Default Smart struts installed...
This is a very unfair comparison, and I really can't tell any of you the difference between the stock strut bracket and the smart struts, because the stock bushings in my car were shot BEYOND BELIEF. Ok, not beyond belief, but pretty damn bad. Some of them were missing at least half the bushing.
Before...
After...
Not much to look at, but the new rods sure are shiny! ;)
The tires make less noise in the corners and the car tracks better. I was not in the mood, plus the car was loaded, so I have not given them a good hard cornering test yet. The guys at the shop couldn't believe how bad my old bushings were. :) Judging from my shock mounts, I'm still running the original ones. Lucky me, haven't had to pay to replace them yet! I'm sure they'll break the next time. :)
Trailing arms this summer!!
-Steve
Old May 21, 2003 | 03:02 AM
Dalannex's Avatar
Dalannex
Default Re: Smart struts installed... (Pacin'California)
Looks good. You didn't have any problems with your tailpipes hitting due to the lower strut rod mounting bracket I take it????? I had to lower my pipes an inch and a half in the back to get them to clear the smart struts bracket. If the pipes were closer to the middle of the diff I would have been alright, but they are slightly to the passenger side so I had some clearance issues. I may have my pipes reworked a little bit to get back in the center of the diff and bring them back up one day. We'll see.
-Justin
Old May 21, 2003 | 03:26 AM
Shark Racer
Default Re: Smart struts installed... (Dalannex)
I managed to get my smart struts in fine, but had to do a pullup on the pipe in order to squeeze the bracket into place. The leaf spring was FAR easier to squeeze through than the SS.
I had a helper. Job took 2.5 hours total... not so bad, I think!
-Steve
Old May 21, 2003 | 04:33 AM
DMONSVETTE's Avatar
DMONSVETTE
Looks good from what I can see. Did you have to do an alignment after
installing the smart struts?
Thanks for sharing the pics.
:seeya
Old May 21, 2003 | 10:45 AM
Shark Racer
Default Re: Smart struts installed... (DMONSVETTE)
Yes, but I installed them at their shortest setting. When the car hit the ground, camber was +1.2/+1.9. I adjusted to -.5 on both sides. The smart struts are VERY easy to adjust for camber. I used an alignment machine at my dad's shop, but there are ways of measuring with a carpenter's level and wood blocks. Tell me if you'd like to know more.
-Steve
Old May 21, 2003 | 10:54 AM
Chuck Harmon's Avatar
Chuck Harmon
Hello Steve!
Your car has to be a real blast to drive now that you've got new shocks and springs too. You probably do, but just wanted to make sure that you know that the car must roll about 30 feet once it is let down off a jack to get accurate camber measurements.
It's been too long. Lets get together after your finals are over.
Chuck
Old May 21, 2003 | 11:01 AM
Shark Racer
Default Re: Smart struts installed... (Chuck Harmon)
Sounds good, Chuck. I was actually over at Tom's house last Sunday, checking out his new grocery getter. (As well as his Top Flight in the garage).
I swung by your house, but no Z in sight, so I just rolled on by. Starting to get a good feel for the neighborhood. Give me another year and I might be able to figure out how to get somewhere other than your two guys' houses!
I'd be more than happy to give you a ride, or better yet, let you take the 78 around the block again. It's night and day compared to what it was when you drove it.
-Steve
Old May 21, 2003 | 11:11 AM
American Boy's Avatar
American Boy
You're gonna love these struts. The -0.5 rear camber setting is great. I ran that setting for a year and 10000 miles and the tire wears straight. The car handle much better with the smart bracket.
Enjoy.
Stephan
Old May 21, 2003 | 11:51 AM
terryrudy's Avatar
terryrudy
Good job Steve! :thumbs:
Glad to hear you're continuously improving her. I need to follow your excellent example and get my butt in the garage!
-terry
Old May 21, 2003 | 04:24 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Steve-
I'm glad the install worked out well for you. After you do some testing let us know what you think.
-Dan
Old May 21, 2003 | 05:56 PM
Shark Racer
Default Re: Smart struts installed... (Van Steel)
Dan- So far, I've had a little bit of fun with my baby. The limit seems to have gone up by a good margin, and the car felt more compliant then before. Just a lot "smoother", more like a new vette. I will continue to do investigating and maybe write another report next week after I've driven the car a bit more.
-Steve
PS Alignment is CAKE with the new rods.
Old May 22, 2003 | 08:09 AM
pws69's Avatar
pws69
-Steve
Steve - please do tell! I will be doing this soon.
Old May 22, 2003 | 11:02 AM
Shark Racer
Default Re: Smart struts installed... (pws69)
http://www.vettebrakes.com/Instructi...t/42009-10.htm
You can use trig to figure out the angle/gap relationship otherwise.
Install is relatively straightforward.
I had to remove the shocks, spring end link nuts, shock mounts, and lower the exhaust so I could feed the brackets through. The stock heat shield never went back on the car, but my exhaust piping looks fine. (I have a good 2" from the spring at that point.) The job took me 2.5 hours w/ air tools. Expect to need a hammer and a pry bar to get the shock mounts and old strut rods out.
-Steve
Old May 22, 2003 | 05:11 PM
PureSilver's Avatar
PureSilver
Noticed the heat wrap on your pipes- is this enough to protect the 'glass spring? (I'm putting one on & am nervous about the potential problem...)
Old May 22, 2003 | 05:19 PM
Shark Racer
Default Re: Smart struts installed... (PureSilver)
Yes- I can barely touch the hot, bare metal pipe, but can wrap my hands around the wrapped area for a long time. It's amazing how much cooler it is in that area.
-Steve
Old May 22, 2003 | 06:43 PM
gkull's Avatar
gkull
When are you getting rid of that heavy spare holder? :seeya
Old May 22, 2003 | 07:05 PM
terryrudy's Avatar
terryrudy
Default Re: Smart struts installed... (gkull)
...and those heavy Iron heads. :jester
Just joshin with ya Steve. I keep telling you, if you keep modifying your car, you're not gonna want to drive it anymore!!!! ;)
-terry
To Smart struts installed...
