Dyeing Seat Belts Question?
I attempted this myself on a set of NOS belts I bought on Ebay, oyster to red. The dye I used was from a quart can I got from Eckler's. Carefully I taped the little white tags off with tape and applied the dye using a brush from the can, no thinner. The paint/dye went on smoothly and soaked right through the webbing. Man did they looked good. After about an hour under the Florida sun, I unhooked the belts from the clothes line and boy did I get a big supprise! The belts were as stiff as an 2by4. Ended up sending them to Ssnake Ole Products for new webbing, $60 bucks each. "Pay the man now or pay him latter!!"
ric :steering:
I was fixing to go through the same as you, but now I won't be waisting my time. Thanks so much for the tip and saving me alot of work. :smash: So do you have info on Ssnake Ole Products and how do I get in touch with them?
YBNormal...drive a vette www.angelfire.com/al/swhite7/interior.html
Completely disassemble the belts. Remove all the tags. Take out all the "jelly rolls" so you can remove all the hardware. Follow the dye directions. Use a pot on the stove. Completely strip all the old dye. The belts will come out a beige/off white color. Use Oxalic acid to remove the rust stains. THEN.....follow the directions and re-dye the belt to your color.
After that's done, you'll need an industrial/commercial sewing machine to reapply the tags, and re-sew the belts. You should make notice of the correct stitching patterns before you remove the tags, and the other hardware.
NOTE: It is technically illegal to re-sew seat belts/repair seat belts, but if you have a relationship with your local trim shop, and you're doing it for restoration purposes, you should be OK. Chuck
W-mail:questions@ssnake-oyl.com
114 N. Glenwood Blvd
Tyler, Texas 75702
800/284-7777
:steering:
[Modified by Ric's80_4sp, 7:31 PM 5/21/2003]
