Emissions in Illinois?
Old May 21, 2003 | 02:30 AM
JohnG76's Avatar
JohnG76
Default Emissions in Illinois?
So today I tried to apply for plates, well turns out epa put a block on me till i pass the emissions test. So what are the odds of me passing with my still non running 76' vette w/
+ GM 350 sm block crate engine
+ edelbrock carb/ performer manifold/ orginal exhaust manifold
+ no catalytic converter
+ i believe that all orginal smog and emissions taken out (prev owner)
any ideas to increase my chances
Old May 21, 2003 | 11:18 AM
77Dream's Avatar
77Dream
Default Re: Emissions in Illinois? (JohnG76)
If its not running then tell them that. They will list it as non-operational and you will have to pay a small fee. Then when you get it running good get it tested. There is no reason to pay for tags on car that doesn't run. However you will need all the smog equipment to pass, they wont even test it if it doesnt pass visual.
Old May 21, 2003 | 01:24 PM
sray454's Avatar
sray454
My '72 ( LS5) passed last year without a problem. Mine never had the C.Converter so that wasn't a problem. Mine did come with a smog pump, but it is long gone. They never opened the hood. They only did the sniff test from each pipe. Passed with flying colors.
I'd have it checked. If it passes great. If not, one option you have is this. In Illinois, car's over 25 years old can be registered as antiques. Antiques do not have to pass emissions test in IL. But there are some downsides to registering as an antique.
Old May 21, 2003 | 02:12 PM
Biker's Avatar
Biker
Default Re: Emissions in Illinois? (sray454)
John, I always get my Illinois emissions test notice in January. I simply check the "not working" box on the postcard, list the date the car can be tested, and then card in the mail.
I once failed the emissions test because I forgot to remove my test pipe and reinstall the catalytic. I failed the test by only one-tenth of a percent in one category. I reinstalled the cat, returned the emissions testing facility the same day and passed the test.
I'd really like to add side pipes to my '81 but there's no way I can do so without using a catalytic.
Old May 21, 2003 | 02:23 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
If your car is not a daily driver but more of an afternoon or weekend cruiser, antique plates are worth considering. Good for five years, too, so you save the yearly fee.
Old May 21, 2003 | 05:05 PM
Edzred72's Avatar
Edzred72
I have removed all the smog stuff from my 77, but I am running headers, intake, cam, heads, Holly, true duals with dual high-flow cats and a crossover. Passed emissions with flying colors last week.
Eddie
Old May 21, 2003 | 05:52 PM
Jvette73's Avatar
Jvette73
Default Re: Emissions in Illinois? (Silvr77)
Go for the antique plates. The downsides are more of an insurance issue than they are a state legal issue. Tell the state its an antique. Then when you insure it dont mention it. You wont have to get emissions test as per state, and youll be fully covered for ins. Would that work?
Old May 21, 2003 | 11:38 PM
bigvette1's Avatar
bigvette1
Default Re: Emissions in Illinois? (Jvette73)
I have a 73bb that has all the stuff pulled by the previous owner. I live in Cook Cty and the test is a sniffer in the tail pipe and on the dyno. They did not open the hood at all. The car passed with flying colors at about 1/2 of the standard. This goes back to the theory of a well tuned engines runs clean.
In your case the missing cat will be a problem because the pollution levels will be way up there. They do not look for it - yet. Might really consider when you do get it tested if you do no go the antique plate route to get the cat on it.
Old May 22, 2003 | 05:33 AM
hunt4cleanair's Avatar
hunt4cleanair
Eddie
Silver77 passed because he burned the crap out of the emissions and left nothing but water and carbon dioxide. The motor was probably looking for more fuel and simply burned lean cause it was fuel starved!
Sray passed caused his 72 didn't come with a cat converter.
Your 76 came with everything and some of these states may simply grandfather these old timers in!
Old May 22, 2003 | 07:18 AM
bigvette1's Avatar
bigvette1
Default Re: Emissions in Illinois? (hunt4cleanair)
Agree of why people passed emission in Ill. The 76 in question came with a CAT and will need one to pass the sniffer testing. The emission standards for that year take this into account. Illinois does not make a visual inspection at this time other than the fuel filler restrictor - and then they write a variance on cars older than 75 without the "unleaded size reducer". Visuals are scheduled in the next 1-2 years when they can get the books together on what to look for.
Old May 22, 2003 | 08:13 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I don't believe you will pass without the cat converter. Aurora and South Elgin look for the cat, it's usually the first thing the guy does. Antique plates are not the way to go because you can (legally) drive the car only in club sponsored events and the like. In the unlikely event of an accident during other types of driving you could be holding the purse strings (scary thought?) If the engine has good compression and runs well you should be able to to a low emissions tuneup and get it to pass (with the cat).
I did some checking as to how far back the Illinois EPA tests, found they can, and do go back to the 1963 model year (the first year for a PCV valve). Only other way to get around the testing, at least for now, is to move out of the Chicago metro area, or register the car to a friend or relative outside of the area.
[Modified by Big Fish, 7:17 AM 5/22/2003]
[Modified by Big Fish, 7:20 AM 5/22/2003]
Old May 22, 2003 | 10:32 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Someone noted they passed withot a C-vertor on a '72...that's because '72s didn't have them. It is like this, they test to the standards for the year of your car. If you should have a convertor on a '76 it may not pass. The did not run my '78 on the dyno, just used the tailpipe probe; i passed, but I have a convertor. I knew a guy a few years ago who would always remove his on his Mustangs and would pass. His secret:
He claimed run the highest octane you can (booster even) He would run it on the highway at about 80mph, and go directly to the emisions station at an off time, say 2pm. He always passed. He claimed with the engine extreemly hot and the carbon cleaned out it will pass. I think you have (3) tries, so you could try this, I never have.
Old May 22, 2003 | 10:34 AM
gliot1's Avatar
gliot1
Default Re: Emissions in Illinois? (gliot1)
One more thing....I see that some noted that the check for the c-vertor in Elgin; same in Crystal Lake. I took mine there and they have a mirror on a pole and they look under the car and note its presence.
Old May 22, 2003 | 10:44 AM
sray454's Avatar
sray454
I remember the debate about low/high octane being better for emissions.
I went with the lowest octane possible - because it burns the fastest. The higher the octane, the slower the mixture burns and the more likely it won't be completely burned by the time it passes by the sniffer. I don't know if this is BS, but it kinda makes sense.
Also, make sure you have no vacumn leaks - in your headlight system. I blocked mine for the test.
Also, I adjusted my idle settings with a vacumn gauge - just set and balance for the highest vacumn you can get. I also checked my timing.
To Emissions in Illinois?
