63-79 Guys
Old May 21, 2003 | 03:30 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default 63-79 Guys
Hey guys we have the Differential Crossmember Reinforcement Plates on sale. They are ususally $34.99 for 2 and we have them on sale for $25 plus shipping. The plates are aluminum and they reinforce the rubber isolators that secure and retain the rear crossmember in place.
Kit includes:
2 - Plates
2 - Bolts
2 - Lock Washers
You can order by phone, e-mail or Internet. It's featured on our homepage.
Dan
800-418-5397
e-mail: vansteel@vansteel.com
Website: Vansteel.com
Old May 21, 2003 | 03:46 PM
Fevre's Avatar
Fevre
Default Re: 63-79 Guys (Van Steel)
Make your website a clinkable link in your sig for us lazy guys. :)
www.vansteel.com
Old May 21, 2003 | 03:48 PM
Fevre's Avatar
Fevre
Default Re: 63-79 Guys (Fevre)
Your website seems to having problems right now.
Old May 21, 2003 | 03:52 PM
Van Steel's Avatar
Van Steel
Thanks, I just called them and they are working on it. It should up soon.
[Modified by Van Steel, 2:52 PM 5/21/2003]
Old May 21, 2003 | 03:56 PM
Jvette73's Avatar
Jvette73
Locator kit. Got em on my car. They are suppose to help hold the crossmember in position and keep it from shifting on the bushings. Since I got the shutterbug today and my cars on stands...wala..heres a pic of them installed. My kit uses a stud and nut instead of bolt. Same diff though.
Old May 21, 2003 | 04:05 PM
Van Steel's Avatar
Van Steel
Default Re: 63-79 Guys (Jvette73)
Thanks for the pic.
Old May 21, 2003 | 04:38 PM
72GACRZR's Avatar
72GACRZR
Do they just drop thru the existing bushing, replacing the existing bolt and sort of clamp it?
How hard is it to put in?
:seeya
Old May 21, 2003 | 05:00 PM
Jvette73's Avatar
Jvette73
Default Re: 63-79 Guys (72GACRZR)
yur welcome van
72GACRZR, its a piece of cake to put em on. Jack the rear and put stands under the frame. Leave the floor jack or put a bottle jack under the diff/center spring to support the weight of the xmember/diff assembly. Remove the existing xmember bolts. Feed the new bolt with washer thru the disc and install. The disc makes contact with the metal part of the xmember when tightened. It makes a more positive connection that way. Helps suppurt the whole unit so its more secure and wont deflect as much when under heavy load such as when upshifting at WOT or when cornering hard.
Old May 21, 2003 | 05:15 PM
Van Steel's Avatar
Van Steel
The site is running again.
To 63-79 Guys
