hey guys if I have a 1980 stock vette and lets say it is an L-48/190 and I want to put the L-82/230 heads on it. would it be possible or are they the same heads.
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: More corvette heads (frosty80vette)
Look for the topic called 1980 heads (or !980 heads to be exact).
In there we discussed the best solutions for the L-48 on a budget.
New 58CC aluminum heads, new cam and lifters, exhaust and some carb tuning should get you a 9.5:1 compression motor that should put out about 300 HP/ 350 lbs trq at the crank and cost about $1500 total.
