Help: Stripped Intake Bolt
Old May 22, 2003 | 08:50 AM
Schwee's Avatar
Schwee
Default Help: Stripped Intake Bolt
My '81 is my daily ride, so I hate to take it down.
To fix a coolant leak, I pulled the second from the front, driver's side, intake manifold bolt and gooped it with RTV blue. To my surprise, I was putting maybe 5 ft lbs of tourque on it when I found that it wouldn't tighten - stripped.
I'm driving it that way and just dabbing the green coolant and adding a little water once a week. I know that I should pull the manifold and re-tap or helicoil the head, but you know how one thing leads to another and I'd like to put off this repair for as long as possible.
Any one have a quick fix without removing the intake?
Old May 22, 2003 | 09:27 AM
Matt Gruber's Avatar
Matt Gruber
Default Re: Help: Stripped Intake Bolt (Schwee)
have you tried a 1/4" longer bolt?
Might hit a pushrod if it is too long.
Old May 23, 2003 | 10:12 AM
Schwee's Avatar
Schwee
Default Re: Help: Stripped Intake Bolt (Matt Gruber)
Thanks, Matt! Why didn't I think of that!!!
I measured the hold and was able to use a bolt 3/4 inch longer.
It tightened down perfectly.
...on the road again (or still!).
Old May 23, 2003 | 10:19 AM
Matt Gruber
:party:
To Help: Stripped Intake Bolt
