How do I wire electric fans?
I just ordered one of these:
It has 3 ignition-hot circuits and a 40 amp relay. I want to use it for the Fans, pertronix, and maybe an MSD in the future.
Where is the best place under the hood to get:
1. a good strong constant 12V and
2. a good ignition source?
My guess is the coil for ignition and starter for 12V
What would be best or better?
Should I get a better higher amp Aternator?
If I were to get a high voltage coil should I use a better power source than the stock wires?
Thanks,
~Jay
[Modified by Jay M, 1:43 PM 5/22/2003]
If you have any questions let me know.
:cheers:
Should I get a better higher amp Alternator?
Thanks,
~Jay
If I were to wire directly to the fuse block, how exactly do I connect the wires?
Is there a place in the back to add new wires?
~Jay
