gas guage readings
Old May 22, 2003 | 08:11 PM
BobSpin's Avatar
BobSpin
Default gas guage readings
put in a new fuel tank in my 71 270/350. I tried 3 new sending units, the guage shows half when in fact i use only about 5-6 gal of fuel, checked ground all seems ok, pull off round plug frm sending unit, guage goes to beyound full, pull off square plug, nothing happens, the gas guage was always fairly accurate with old tank and sending unit. Im original owner 73000 miles, car is all original. Need some advice to correct, thanks
Old May 22, 2003 | 08:13 PM
sb69coupe's Avatar
sb69coupe
Default Re: gas guage readings (BobSpin)
Get an ohm-meter and check the resistance of the sending unit. It should go from almost zero ohms at empty to around 90 ohms at full.
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
What happened to the original sending unit? Does it no longer work after the tank swap as well ?
Welcome to the forum.
Old May 25, 2003 | 07:15 PM
BobSpin's Avatar
BobSpin
Default Re: gas guage readings (BSeery)
Thnaks for the help, the old sending unit was accidentally discarded, I broke my own rule about if you want to keep it, grab it right away.
Old May 25, 2003 | 10:38 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Welcome to the forum. Please register your 71 at http://www.71corvette.com
To gas guage readings
