dif drain plug kit
Old May 23, 2003 | 10:26 AM
1yy07's Avatar
1yy07
Default dif drain plug kit
what was the tele # for the cvt place that had the dif drain plug kit?
Old May 23, 2003 | 10:34 AM
79VetteMike's Avatar
79VetteMike
Default Re: dif drain plug kit (1yy07)
I didn't know they make a kit. I want one also.
Old May 23, 2003 | 11:09 AM
pws69's Avatar
pws69
The kit is available from:
Corvette Clinic
Dept. CF
701-D Cornwall Rd.
Sanford, Fl
32773
phone # is (407) 323-0128
Or online at http://www.corvetteclinicinc.com
Old May 24, 2003 | 09:33 AM
1yy07's Avatar
1yy07
Default Re: dif drain plug kit (pws69)
THANK YOU pws69 :cheers:
Old May 24, 2003 | 09:39 AM
norvalwilhelm's Avatar
norvalwilhelm
Why do you need a kit. If it is a drain plug all you need is to borrow a pipe tape of say 1/4 npt, drill a hole in a convenient spot, tap the cover and install a pipe plug.
To dif drain plug kit
