Exhaust popping update....
Old May 24, 2003 | 03:39 PM
Metal Wulf's Avatar
Metal Wulf
Default Exhaust popping update....
When the #2 cylinder spark plug wire is disconnected the pop goes away...
what the hell does that mean??
I haven't tried changing out spark plugs or anything yet, won't have time to play around with it til tomorrow...
Old May 24, 2003 | 04:54 PM
Jvette73's Avatar
Jvette73
Default Re: Exhaust popping update.... (Metal Wulf)
That could mean that #2 is the one that is firing out of time due to cross fire in the cap. so what cylinders are closest to #2 in the cap? Lets see...the firing order goes 18436572. So I would say maybe a bad plug or wire in either #7 or #1 since those are the ones that are next to #2 in the cap. so when the charge for 1 or 7 can make ground thru the plug for whatever reason, that charge will find the next closest path to ground. So it could be jumping to post #2 in the cap. #2 fires out of time with the exhaust valve open and POP!!!
Old May 24, 2003 | 06:29 PM
71coupe's Avatar
71coupe
Default Re: Exhaust popping update.... (Jvette73)
Jevette 73 - Good reasoning, but how can you get a fire on a cyl that was just lit? It could be a weak spark or bad plug on that cyl #2 too (not getting full burn) which would back up your theory.
One thing you could check is for a vac leak. My other car use to pop like crazy in gear going down a hill. I found a small vac line disconnected. Hooked it up, no more popping. Another thing that will cause popping is a bad diverter valve on your A.I.R. system. (if you still have the smog hooked up)An easy check on this is to look at the rubber hose that goes into the exhaust manifold from the smog pump. If it's dried out or burnt looking, the valve is bad.
If you still have the problem, do a compression test. The #2 cyl may have a bad exhaust valve - hope not :(
Old May 24, 2003 | 06:41 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Exhaust popping update.... (71coupe)
thanks guys, I'll be playing with it tomorrow, changing out plugs and simple crap like that.
i'll post an update, if I figure anything out...
Old May 24, 2003 | 07:23 PM
Jvette73's Avatar
Jvette73
71coupe, good point on the posibilty of burnt exhaust valve in #2.
I can personaly attest to the fact that unburnt gasses in the exhause will cause a pop when a plug fires out of time. I traced this exact problem with now cure. My bro came over one day and listened to it. He explained to me the situation as I have repeated. When I changed the plugs the problem was solved. I had one bad plug that would not let the charge ground. So it jumped posts to the adjacent cylinder in cap order and fired that one out of time causing the popping.
Old May 24, 2003 | 07:34 PM
71coupe's Avatar
71coupe
Cool - learn something new everyday :cheers:
Old May 24, 2003 | 07:58 PM
Metal Wulf's Avatar
Metal Wulf
does the rotor spin clockwise or counter clockwise?
I want to check the wires and sure nothing messed up there...
Old May 24, 2003 | 11:54 PM
redwingvette's Avatar
redwingvette
Clockwise.
Old May 25, 2003 | 12:04 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Exhaust popping update.... (redwingvette)
Clockwise.
thanks :seeya
Old May 25, 2003 | 01:36 PM
Metal Wulf's Avatar
Metal Wulf
FIXED THE EXHAUST POP!!!
the god damn #2 plug wire was in the #4 slot :cuss
wonder how long it's been that way :crazy:
Old May 25, 2003 | 01:41 PM
Jvette73's Avatar
Jvette73
:cheers: I think she should run a bit better now considering you had to be running on 6 instead of 8 with two wire crossed. :cheers:
Old May 25, 2003 | 01:47 PM
Metal Wulf's Avatar
Metal Wulf
it's going to run a lot better, I just put my LARS-jet carb on :jester
need to do a little tuning and she'll be running a lot better :yesnod:
to bad it's raining, and isn't suppose to let up til next saturday!!
thanks for the help :seeya
To Exhaust popping update....
