Front Wheel Bearings
When I took it in last year, the guy at Firestone told me that I needed to repack my front wheel bearings.
When I took it earlier in this year to my mechanic (a vette only mechanic, who I trust very much)... I told him that the front wheel bearings needed to be done. He said that the Firestone guy was wrong, and that there were no more play then is normal for a Corvette. Said that he gave them a 1/4 turn and they'd be fine. (Not sure what he meant by the 1/4 turn part, but really isn't the point of this question.)
Today when I was at Firestone, the tire tech told me that both of my front wheel bearings were "shot". (Completly different Firestone location, and completly different tire tech..)
Here is my question.
Anyone else had this kind of experience...
Are the Firestone guys taught to 'over-prescribe' front wheel bearing jobs?
Or, do I have a mechanic who just didn't feel like doing a wheel bearing job?
Thanks.
:withstupid:
From my experience alot of tire places try to sell you all they can for parts you dont need. I had a "tech" tell me that my rear diff fluid needed changing....in my fwd riviera.
As for what he means by a 1/4 turn. If you look at your bearings theres just a large castle nut that controls the amount of play in the bearing.
Repacking the bearing means taking the bearings out, washing them off, putting them back on (always putting new grease seals on), putting new grease in the bearings, then setting the play.
If you're concerned about all this, all you do is take the wheel off, pry off the grease cap on the rotor and look for yourself. Make sure the grease isnt black and charred looking. as for bearing play, the best way i know to set it is just take the cotter pin out of the spindle nut, give the rotor a good spin, then with a adjustable wrench crank down on the spindle nut until the rotor stops. You dont need to wail on it, just give it a sharp turn until thats just enough to stop it, you may to loosen it back up and do this several times until you're satisfied. Then you just put cotter pin back in (you mayneed to move the nut slightly to get it back in) tap the grease cap back on and you're done.
As for giving it a quarter turn that is crued way of doing things.
Setting the front wheel bearings is critical to your front brakes. The runout including rotor wobble plus bearing play must be under .010 so yes setting the front bearings is more then just tightening the nut up and backing it off to the nearest cotter pin hole. It might even involve valve shims. Yes valve shims to get it right.
Firsestone= Poor quality and service in my book :U
As far as shims go, you'd only need those on if you're having problems with brake pulsations. In which case you'd probably just get new rotors anyway.
