Do you use sealant when rebuilding calipers - Help quick
Old May 25, 2003 | 03:44 PM
Justin79-L-82's Avatar
Justin79-L-82
Default Do you use sealant when rebuilding calipers - Help quick
DO you put sealant on the o-rings and/or the dust boot part around the piston or do you just lube everything with brake fluid
Old May 25, 2003 | 03:48 PM
Larry B.'s Avatar
Larry B.
Default Re: Do you use sealant when rebuilding calipers - Help quick (Justin79-L-82)
No sealant ... Just brake fluid. I've never had any problems.
