Getting Ready To Order My Leaf Spring
Old May 25, 2003 | 07:39 PM
bence13_33's Avatar
bence13_33
Default Getting Ready To Order My Leaf Spring
Well I'm getting antsy because I can't go drag racing until I change my leaf spring. If you recall my stock 9 leaf rear spring wasn't strong enough and my rear suspension was going solid during launch. That caused some crazy bouncing and my halfshafts are going over center.
I have decided to go with the 420lb composite spring from Eckler's for $300.
What kind of weight savings can I expect by changing from a steel 9 leaf spring to a composite rear spring?
Once I get the spring, I'm going to lean out my motor a little more (still a little too rich) and take the 'Vette back to the track in hopes of an 11 second pass. Thanks :cheers:
Old May 25, 2003 | 08:16 PM
Corey_68's Avatar
Corey_68
Default Re: Getting Ready To Order My Leaf Spring (bence13_33)
Shane when I switch to the fiberglass rear sping I saved about 50lbs give or take a few pounds. It really cleaned up the rear end as well. :thumbs:
Old May 25, 2003 | 08:46 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Good choice going with the 420lb spring. And I agree... it dumped about 50lbs of weight going with the composite monospring.
Old May 25, 2003 | 10:00 PM
bence13_33's Avatar
bence13_33
Default Re: Getting Ready To Order My Leaf Spring (Corey 68)
Corey:
Thanks. That's .05 of a second down the 1/4 ;) . My car just bounces like crazy coming off of the line because of my weak rear spring. I didn't see much sense in going with a steel 7 leaf spring.
P.S. I was being serious about the .05 of a second thing. I've won races by .01-.05 of second in heads up races. So I guess that's how I justify spending $200 more for the composite spring.
Old May 25, 2003 | 10:26 PM
Corey_68's Avatar
Corey_68
Shane, think of it this way. .05 is half a car length, that's the difference between winning and losing. :thumbs:
To Getting Ready To Order My Leaf Spring
