Cleaning aluminum intakes
Old May 26, 2003 | 03:11 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Cleaning aluminum intakes
She's got 4500 miles on her and she's dirty :nono: :nonod: :nonod: :sad:
I can keep the valve covers clean. I can spit shine most of it but then there's that intake. Mine is not a polished one; it's natural finish. (Edlebrock Performer)
How do ya clean all them nooks and crannys by each bolt on the manifold?
Old May 26, 2003 | 07:56 AM
Paul L's Avatar
Paul L
Default Re: Cleaning aluminum intakes (SanDiegoPaul)
I use Simple Green and a toothbrush. Sounds bizarre but it works.
Old May 26, 2003 | 08:00 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Cleaning aluminum intakes (paul79)
NaOH (oven cleaner) and a good pressure washer
Old May 26, 2003 | 11:15 AM
SanDiegoPaul
Default Re: Cleaning aluminum intakes (Twin_Turbo)
Simple Green and a toothbrush? YOu mean I can use the same two tools under my hood that I use on my teeth? WOW :jester
As for the oven cleaner, yea I'm sure it would work but this is a new motor and its not THAAAAT dirty. And on my Nova I remember using a pressure washer on that intake. Wow what a mess! Took longer to clean myself and the car up afterwards than it was worth!
Thanks guys
Old May 26, 2003 | 11:52 AM
Twin_Turbo's Avatar
Twin_Turbo
how can you get dirty if it's not that dirty at all :p: :lol:
Old May 26, 2003 | 11:53 AM
79VetteMike's Avatar
79VetteMike
carb cleaner
Old May 26, 2003 | 11:59 AM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: Cleaning aluminum intakes (79VetteMike)
Try Brake clean and an air hose.
Old May 26, 2003 | 12:07 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
with the oven cleaner, wouldn't you be risking a chance of damaging fiberglass if you get it on it? Even if you are careful, you still gotta factor in the oops factor...
Old May 26, 2003 | 12:10 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Cleaning aluminum intakes (Aflac)
don't know, my paint was crap anyway and whenever I did something like that I made sure I had everything covered up just fine. Brake cleaner WILL mess up your paint (and windscreen too), oven cleaner most likely will not damage the paint.
Old May 26, 2003 | 12:16 PM
Aflac's Avatar
Aflac
St. Jude Donor '09
i like the concept of the simple green better... call me chicken *looks over shoulder and sees feathers poppin out...
Old May 26, 2003 | 02:39 PM
Paul L's Avatar
Paul L
Sodium hydroxide is very caustic. It will chew up paint very quickly.
Old May 26, 2003 | 04:32 PM
arrio76's Avatar
arrio76
Years ago I used a syphon air gun/nozzle with solvent or detergent solution, depending on what I was cleaning. Used it on military helicopters to get to hard to access areas for cleaning. Didn't use a Lot of presure, just enough to work with the cleaning solustions. Not near as messy as the presure washer. should work well on the light oil/dirt films. Be sure that the solution is clean. Any dirt in the solution will act like a blast media. (sandblast)
Old May 26, 2003 | 04:38 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I tried some Simple Green on a remote control car chassis (recommended by the car company) to remove caked on dirt and nitro / alcohol fuel.
It removed everything alright !! Including the blue anodizing from the aluminum chassis !! I don't know if that was a manufacture f' up or not but I don't use simple green around anodized parts now. I did get a new chassis from the company and it came packaged with a note saying "don't use Simple Green! Use WD-40."
Also, back when Castrol came out with that purple spray Super Clean stuff I made the mistake of using that on a motor cycle.
It fogged the clear coat on the wheels, turned the aluminum engine covers white and washed the paint right off the fuel tank :eek: Stay away from that crap !
Old May 26, 2003 | 06:45 PM
Chris O''s Avatar
Chris O'
A small wire brush does the trick!
To Cleaning aluminum intakes
