Question ,,,,, hyd clutch
Old May 26, 2003 | 12:47 PM
ram82fire's Avatar
ram82fire
Default Question ,,,,, hyd clutch
What was the first year the hydraulic clutch was installed in a vette ?
gman
Old May 26, 2003 | 10:33 PM
ram82fire's Avatar
ram82fire
Default Re: Question ,,,,, hyd clutch (ram82fire)
TTT
Old May 27, 2003 | 08:16 AM
norvalwilhelm's Avatar
norvalwilhelm
I don't know what year the hydraulic clutch appeared in the corvette but I do know that the 85 one ton truck clutch master cylinder bolted into my 75 with only a linkage change. The hole in the firewall was there with a cover plate over it along with the mounting holes. So after shortening the linkage which just involves cutting it shorter and running a die over it , it bolted right in. I also used the bellhousing from the same truck because is fit an 11 inch clutch and had a slave cylinder on the side.
Old May 27, 2003 | 09:29 AM
mapman's Avatar
mapman
gman
1984. Dave McLellan's book "Corvette from the Inside" page 83 has a discussion on the hydraulic clutch. It was done to restrict drive line loads from people "dumping" the clutch.
Old Jun 1, 2003 | 12:27 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Question ,,,,, hyd clutch (norvalwilhelm)
Great info. I'll have to get one of those. I have a ZF-6 cylinder and although it fits it's just not how I want it to be.
Old Jun 1, 2003 | 02:11 PM
ram82fire's Avatar
ram82fire
Default Re: Question ,,,,, hyd clutch (Twin_Turbo)
Marck I am going to pick up all the drive line pieces this week for my change over . I will send some pics of the slave and master cylinder when I pick them up .
gman :seeya
Old Jun 1, 2003 | 02:27 PM
Twin_Turbo's Avatar
Twin_Turbo
:thumbs:
To Question ,,,,, hyd clutch
