Installing Big block into C3
Old May 27, 2003 | 10:44 AM
Torque Crazy's Avatar
Torque Crazy
Default Installing Big block into C3
I've been told the new big block can't be installed in my C3 without removing the heads. Is that true?
Old May 27, 2003 | 10:47 AM
Corey_68's Avatar
Corey_68
Default Re: Installing Big block into C3 (Torque Crazy)
That's false, all of the the Big Blocks are the same size physically, so they will all fit.
:cheers:
Tom73's Avatar
Tom73
C3 was originaly designed for the big block, basicly a bolt in operation.
tom...
Old May 27, 2003 | 11:14 AM
djcwardog's Avatar
djcwardog
I did this a few years ago with another car. You do have to remove the stock big block exhaust manifolds even though they hug tight and appear that they would drop right in with the motor... Heads can stay on... I also put the motor in alone, with the tranny (manual) and bellhousing already there waiting for the motor. Other folks put the whole package in as an assembly.
Old May 27, 2003 | 06:30 PM
joe73vette's Avatar
joe73vette
Default Re: Installing Big block into C3 (djcwardog)
The thing you have to work with is there is no fuel pump boss on the 502's, only 454's. Joe
Old May 27, 2003 | 06:36 PM
Corey_68's Avatar
Corey_68
Default Re: Installing Big block into C3 (joe73vette)
454 H.O's do NOT have mechanical pump bosses as well.
Old May 27, 2003 | 11:44 PM
ORVette's Avatar
ORVette
Default Re: Installing Big block into C3 (Corey 68)
My 454HO has a mechanical pump boss. I'm running a mechanical pump. Do yourself a favor though, go electric.
Old May 28, 2003 | 12:17 AM
Corey_68's Avatar
Corey_68
Default Re: Installing Big block into C3 (ORVette)
Really? I have a Gen V 454 H.O. and I have no boss. I wonder why you have one and I don't since it's the same engine? I'm running an electric Holley blue 110gph .
:cheers:
Old May 28, 2003 | 01:12 AM
ORVette's Avatar
ORVette
??? I don't know? Mine is actually a Gen. VI block. I think it was assembled in '98 if I remember right from the build tag. Anybody else know why the difference? :confused:
Old May 28, 2003 | 01:32 AM
75 Stingray!'s Avatar
75 Stingray!
I think the crate BB came with the fuel pump boss and the others did not.
Old May 28, 2003 | 01:42 AM
Corey_68's Avatar
Corey_68
Default Re: Installing Big block into C3 (75 Stingray!)
Mine was a crate BB as well.
:cheers:
Old May 28, 2003 | 04:18 AM
BB73Chris's Avatar
BB73Chris
ORVette which intake is that on there? It looks pretty low does it fit under your '73 hood? I assume it's for oval port heads is that right?
Old May 28, 2003 | 09:31 AM
MassVette's Avatar
MassVette
My Gen VI 454 HO has a mechanical fuel pump boss. Works fine with TriPower-
:yesnod:
[Modified by MassVette, 9:32 AM 5/28/2003]
Old May 28, 2003 | 10:04 AM
Corey_68's Avatar
Corey_68
Default Re: Installing Big block into C3 (BB73Chris)
His engine is a rectangle port like mine. His stock intake (high rise) is the one on the floor next to the engine.
[Modified by Corey 68, 12:41 PM 5/28/2003]
Old May 28, 2003 | 01:31 PM
ORVette's Avatar
ORVette
The intake I have is casting# 3963569. It is a 70-71 LS6 low rise, as far as I know. Corey is right, it is for rectangle port heads. I think you have a few more options with oval port intakes, but yes, this one fits under a stock '73 hood with a little room to spare. I think I paid $200 for it from another forum member.
To Installing Big block into C3
