Stainless Steel Flowmasters
Old May 27, 2003 | 10:42 PM
mvftw's Avatar
mvftw
Default Stainless Steel Flowmasters
I'm planning on getting Stainless Steel 50 Series Delta Flowmasters. Are they a better choice then Aluminum? I assume they are...
Old May 28, 2003 | 09:37 AM
ZD75blue's Avatar
ZD75blue
Default Re: Stainless Steel Flowmasters (mvftw)
Should last forever...
:cheers:
Old May 28, 2003 | 03:13 PM
Alwyn678's Avatar
Alwyn678
The construction is the same one is Aluminzed with a one year warranty and the Stainless has a Lifetime warranty and is 20 bucks more or so
[Modified by Alwyn678, 3:16 PM 5/28/2003]
Old May 28, 2003 | 03:28 PM
mvftw's Avatar
mvftw
Default Re: Stainless Steel Flowmasters (Alwyn678)
There shouldn't be a problem to weld Aluminzed pipe to a S/S muffler?
Old May 28, 2003 | 07:05 PM
dath's Avatar
dath
Naww, they should weld up just fine. It's the factory pipe they put on new cars that's a pain in the rear to weld, at least if you're trying to do it with something other than a wire feeder...
Old May 28, 2003 | 07:41 PM
Jvette73's Avatar
Jvette73
I recomend clamping rather than welding. Especially with stainless. The heat from the weld will ruin the stainless qualities and thats where it will eventually fail. Ive had many of aluminized systems put on different vehicles in the past. The aluminized pipes themselves will also last almost forever. They always break right where therye welded. If you clamp it togeather and use stainless clamps, now that will last forever.
[Modified by Jvette73, 6:42 PM 5/28/2003]
To Stainless Steel Flowmasters
