Caliper Painting
Old May 28, 2003 | 09:40 AM
Mystery Machine's Avatar
Mystery Machine
Default Caliper Painting
The topic I know has been covered but searching the archives didn't reveal the answer I'm looking for...I am installing new shocks and coil springs soon and figured since i will have access I might paint my rusty old calipers and was wondering what paint to use. Any tips? I was thinking about trying that black paint they have at Wal-Mart for BBQ grills...it says "High temperature" ont it.
Thanks. :thumbs:
Old May 28, 2003 | 10:06 AM
BeachinVette's Avatar
BeachinVette
Default Re: Caliper Painting (Mystery Machine)
Dan
I used Dupli-Color High Temp Paint @ Wal-Mart. 1200 degree paint. I love that stuff it is a ceramic paint. I think it will last forever. I use it on everything.
Bob
Old May 28, 2003 | 10:08 AM
81vette's Avatar
81vette
Eastwood also carries paint for calipers.
Mark
Old May 28, 2003 | 10:30 AM
Scooter70's Avatar
Scooter70
Default Re: Caliper Painting (BeachinVette)
Dan
Bob
I just put this same paint on my calipers this last weekend. Looks sweet. With your TT2s, how about silver or red? I did mine in silver, but they don't show through as much with my wheels. I'm pretty happy with the outcome.
Old May 28, 2003 | 10:59 AM
Corey_68's Avatar
Corey_68
Default Re: Caliper Painting (Scooter70)
VHT makes a caliper paint and you can find it at O'Reilly Auto Parts. They may have to order it but can get it in next day for no charge.
Old May 28, 2003 | 11:20 AM
zymurgist's Avatar
zymurgist
Default Re: Caliper Painting (81vette)
Mark
That Eastwood paint is a 2 part paint. You have to work fairly quickly but it's da shiznit!
Old May 28, 2003 | 11:36 AM
adamdinat's Avatar
adamdinat
I think i read this on corvettefaq.com. It was actually a forum post. Apparently the calipers do not get hot enough to require the high temp paint. I used engine paint on mine. My thinking was the calipers look a lot like the engine block surfaces so coverage and chemical resistance would be good.
Old May 28, 2003 | 01:06 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
I would be hesitant of using anythign other than caliper paint. I used the POR-15 engine paint system on my daily driver. It lasted good for about a year before the brake dust started eating away at the color coat. The underlying coat of protectant is still there but instead of being bright red they are now pale orange/yellow two years later.
Old May 28, 2003 | 01:15 PM
redvetracr's Avatar
redvetracr
I can tell you (from recent experience) whatever paint they use at VBP is pure poopie, as I sprayed Brakleen on a caliper half to wash it before assembly the silver paint was all over my hands and two cans later it was paint free.
...redvetracr
Old May 28, 2003 | 02:31 PM
norvalwilhelm's Avatar
norvalwilhelm
Calipers do not get hot enough to burn normal paint. I am not a racer but sometimes make a few 100 mph panic stops to check brake performance and mine are done with normal paint and never show signs of burning.
I do run silicone brake fluid to protect the paint under the hood. I am forever doing something foolish.
Old May 28, 2003 | 03:41 PM
Brettmc's Avatar
Brettmc
Lotsa folks said you can pretty much use just about any paint. Please don't do black. That would be boring. For your green car, the match is a little more difficult. How bout a nice shade of average yellow? Not the screaming yellow, but the subdued hue. I think it would look A LOT better than black and really set off your TT2s.
Brett :thumbs:
Old May 28, 2003 | 04:20 PM
Mystery Machine
Default Re: Caliper Painting (Brettmc)
Thansk everyone!
Brett, I was actually thinkign of a color that might look good. At first I thought black but I really like the gold on Norval's. Thanks for the ideas!
:thumbs:
Old May 28, 2003 | 04:49 PM
Brettmc's Avatar
Brettmc
Yes, gold is an excellent choice. I painted the calipers on my silver 98 Camaro SS bright red. I loved it and had several compliments on it. Either way you go, it'll be lots better than the color they are now.
Brett :thumbs:
Old May 29, 2003 | 01:19 AM
MN-Brent's Avatar
MN-Brent
I did mine red with Plastikote caliper paint from Walmart. It looks great. I used a wire brush on a drill and went to town cleaning. Before I painted I used brake cleaner to final degrease them up.
I hate to be the same old boring, but I think red would look excellent with a green vehicle. :cheers:
Brent...
Old May 29, 2003 | 01:29 AM
VETDRMS's Avatar
VETDRMS
Default Re: Caliper Painting (MN-Brent)
I recently did this, but with a twist. I have been waiting to get it back together so I can get a picture. I took my T-Top down to a local sherwin-williams automotive paint center where they computer matched the color of my car and put it into an aresol can! Its good to 600F and they even added some pearl to get a closer match to my paint. I think it looks pretty trick and i'll post a picture as soon as its back together.
It also wasn't that expensive, $9 per can (half pint)
:cheers:
[Modified by VETDRMS, 11:31 PM 5/28/2003]
Old May 29, 2003 | 06:10 AM
Mystery Machine
Default Re: Caliper Painting (VETDRMS)
:cheers: [Modified by VETDRMS, 11:31 PM 5/28/2003]
That is a great idea...maybe I'll give that a try.
Old May 29, 2003 | 08:53 AM
ImBatman's Avatar
ImBatman
Here is what I did. I used a high temp base coat then used Krylon purple and covered that with 2 thick coats of high temp clear. Looks good now and but I am sure will need to be retouched periodically.
To Caliper Painting
Old May 29, 2003 | 08:58 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I used Red Devil Polyurethane Red....brushed it on. Not hi-temp. :thumbs:
Old May 29, 2003 | 09:09 AM
Steve Adkins's Avatar
Steve Adkins
Default Re: Caliper Painting (Corey 68)
:iagree: This is what I used and it worked great. I got mine at Advance Auto.
Old May 29, 2003 | 04:31 PM
WESCH's Avatar
WESCH
Hi
I used caliper spray paint in cans.
Just cleaned with wire brush and degreased. No primer, just the paint.
Sticks OK.
I had to go for red for the obvious reason as you can spot. :lol:
rgds Gunther
