Cable Drive Tachometer Question?
Old May 28, 2003 | 03:42 PM
cor72vette's Avatar
cor72vette
Default Cable Drive Tachometer Question?
On a cable drive tach (72) is there a componenet in the tach which keeps the needle from bouncing? My tach works, but has recently become very inaccurate and the needle bounces when when I let off the gas. :skep: Thanks!
Old May 28, 2003 | 03:51 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Cable Drive Tachometer Question? (cor72vette)
i think they a magnetically damped with small magnets :chevy
Old May 28, 2003 | 04:15 PM
cor72vette's Avatar
cor72vette
I forgot, any ideas what may be the cause of this?
Thanks again!
Old May 28, 2003 | 04:24 PM
vettfixr's Avatar
vettfixr
It's probably binding of the cable. I believe you can remove the inner drive cable without getting under the dash. Just unscrew the cable from the distributor and pull the cable inner cable out. Lube it with speedometer lube and then slide it back in. Make sure it's fully seated when you get it back in by turning the cable until it's in as far as it will go. Then reconnect it to the distributor and try it out.
Old May 28, 2003 | 04:31 PM
cor72vette's Avatar
cor72vette
Default Re: Cable Drive Tachometer Question? (vettfixr)
Actually, I have replaced the cable so I doubt it's binding. :( Any other suggestions?
Old May 28, 2003 | 04:49 PM
bbeck's Avatar
bbeck
:confused: mine bounces a bit too. I would also be interested in a remedy :yesnod:
Old May 28, 2003 | 07:27 PM
vettfixr's Avatar
vettfixr
Try disconnecting it and chucking the end in a drill. If the needle doesn't bounce you may have too much of a bend in the cable going into the distributor which could cause binding. If the needle still bounces it might be time for a new tach.
Old May 28, 2003 | 08:07 PM
cor72vette's Avatar
cor72vette
ok, I just put my dewalt on the cable and the best I can determine is the needle still bounces. :cuss So, I guess it's in the tach itself. Any reccomendations for rebuilding it myself or sending it somewhere? Cosmetically the tach is perfect, it would be a shame to discard it. Or where might I find an excellent quality used one?
Old May 28, 2003 | 09:06 PM
vettfixr's Avatar
vettfixr
The only place I know offhand is Clocks by Roger. He shows his stuff at Carlisle and the work is excellent. If I remember right he was pretty dear as far as prices go. This might not make a difference if you want to keep your original parts. You might want to check with ZIP or Mid America to see what a replacement costs also. I replaced mine years ago with one from Mid America and I don't think anyone could tell that it's a replacement.
Old May 28, 2003 | 09:48 PM
Mike Mercury's Avatar
Mike Mercury
if it does this with a drill spinning the cable; then probably the magnet is rubbing against the speed cup (inside the tach). You would need to remove the tach and either:
* straighted out the wobbly speed cup, or
* replace the main shaft housing due to the bearing surface being enlarged... causing too much side play.
one other possibility is that the cable is slightly too long (the cable... not the outer casing). With pressure trying to push each end of the cable towards each other... it will try to flop around in the casing. It this were the problem, then you would of seen good results with your electric drill experiment.
Old May 28, 2003 | 10:03 PM
cor72vette's Avatar
cor72vette
Default Re: Cable Drive Tachometer Question? (Mike Mercury)
Good info. THANKS! :thumbs: Do you know where would I find replacement parts for the tach?
Old May 28, 2003 | 10:40 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
I bought a aftermarket cable, I think my inner cable is too short. It's driven me crazy.
Old May 29, 2003 | 11:07 AM
vettfixr's Avatar
vettfixr
You know a cable driven tach isn't really all that different from a cable driven speedometer. Maybe you could check your yellow pages or a few local speed shops and see if there's anyone in your area that does speedometer repairs. You might be able to have them check it out or purchase whatever parts are needed from them. Or take a look in Hemmings where I'm sure you'll find a ton of repair facilities. Just a thought.
To Cable Drive Tachometer Question?
