Starter Removal - Big Block
Old May 28, 2003 | 11:18 PM
Kim72's Avatar
Kim72
Default Starter Removal - Big Block
I need to remove my starter on my 72 - 454 c/w "Hooker" headers. The solenoid is bad. Looks like the header has to come off first. I would rather not take that off. They have header rap on them and I don't want to disturbe it. Anyone with experience with this. Can the starter be removed without touching the header??
Old May 29, 2003 | 09:05 AM
Brettmc's Avatar
Brettmc
Default Re: Starter Removal - Big Block (Kim72)
You might be able to back off the header bolts enough to get the header to move out of the way. You might hafta unbolt the collector too. Might as well replace the header & collector gaskets while you're at it.
Brett :thumbs:
Old May 29, 2003 | 10:50 AM
Marks69BB's Avatar
Marks69BB
Default Re: Starter Removal - Big Block (Brettmc)
I used to have Hooker SC headers and was able to loosen the header bolts at the cylinder head to drop the starter. It's still a very tight squeeze and the weight of the starter makes it time consuming to remove. Now with the sidepipes it is no longer an issue! :D
BTW, if you have a leaking oil pan, you could drop it instead while you replace the gasket.
[Modified by Marks69BB, 9:52 AM 5/29/2003]
To Starter Removal - Big Block
