??? springs for curv kit
Old May 29, 2003 | 06:33 PM
1st time's Avatar
1st time
Default ??? springs for curv kit
i sure do need help on what springs to use i bought a curv kit and am not sure how to choose spring rate i have a 81 c3 no smog or computer i have a stock 350 # matching hei no computer
:smash:
[Modified by 1st time, 11:46 PM 5/29/2003]
Old May 29, 2003 | 09:47 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: ??? springs for curv kit (1st time)
Different combinations of engine, trans, gearing, car weight, etc., work better with different springs so there's no one answer for all situations. The goal is usually to get the advance in as soon as conditions allow so I'd just start with the lightest springs and test drive it. If you get pinging or other problems, move up to the next heavier springs. You can mix the springs also, using a light with the next heavier one to get the right combination for your particular application.
Keep in mind that the springs only affect the rate of advance, not the amount.
Old May 29, 2003 | 09:53 PM
joeveto's Avatar
joeveto
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
:iagree:
Basically what he said. Drive it and listen. If you have a balancer that's marked, or an advance timing light, you can run through the revs and look at where you are. 34-36 degrees, in as early as possible, without pinging, is best.
Your curve kit should come with instructions that outline what color springs will do what for you. But this is only a guideline, as engines differ.
To ??? springs for curv kit
