Where to mount a shift light?
Old May 29, 2003 | 07:35 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Default Where to mount a shift light?
Looking for pics if possible. I have a small light (MSD) and my car has a tilt wheel.
Thanks! :flag
Old May 29, 2003 | 08:15 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Default Re: Where to mount a shift light? (SanDiegoPaul)
Paul,
I've got the Proform Shift Lite mounted on my steering column. Also, with tilt steering like you. GM made sure it was pretty hard to mount one of these things with the indicator & tilt steering lever being exactly opposite the ignition switch. I worked it out, but it does limit the upward movement of the steering wheel as the Lite gets in the way. I used some small rubber hose to cover the wires to make it look semi-clean and routed the wires through the firewall to the MSD box and grounded to the frame.
Old May 29, 2003 | 08:17 PM
QuickVet's Avatar
QuickVet
Default Re: Where to mount a shift light? (bgrice)
on my L88 hood, i put it under the cowl
Old May 29, 2003 | 08:34 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Where to mount a shift light? (QuickVet)
i did the same as quickvet its in my cowl induction hood.
Old May 29, 2003 | 08:45 PM
Crash Dummy
Default Re: Where to mount a shift light? (patsnitrovette)
Paul,
If you've got the *mini-lite*, I agree with QuickVet & Pat. Under the cowl is probably the cleanest place.
Old May 29, 2003 | 08:55 PM
1Bad69's Avatar
1Bad69
i would flush mount it if possible between the tach and speedo...
To Where to mount a shift light?
