Oil?
Old May 31, 2003 | 12:08 AM
Scudd's Avatar
Scudd
Default Oil?
C3 owners - what brands and weights of oil do you use?
Old May 31, 2003 | 12:11 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: Oil? (Scudd)
castrol 20W50. had bad luck runing synthetics with flat tappet cam.
Old May 31, 2003 | 12:15 AM
SharkAttack's Avatar
SharkAttack
Castrol GTX 10W-40. I only use synthetics on the daily drivers.
Old May 31, 2003 | 12:16 AM
69vette66's Avatar
69vette66
Default Re: Oil? (SharkAttack)
vavoline 40 weight
:cheers: Larry
Old May 31, 2003 | 12:17 AM
joe73vette's Avatar
joe73vette
NAPA 10W-30, but I burn oil so cheaper is better. Joe
Old May 31, 2003 | 12:21 AM
Rockn-Roll's Avatar
Rockn-Roll
Pennzoil 20W-50 off the shelf for everyday driving with an STP oil filter from Autozone. But, for racing I buy a case of Pennzoil 20W-50 Racing Oil.
Old May 31, 2003 | 03:53 AM
Paul L's Avatar
Paul L
I use Castrol 10W-40 also. Good range for the cool times (10W) and the blistering heat of summer on the 40 side.
Old May 31, 2003 | 04:40 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Oil? (paul79)
Valvoline 30w. pretty much year round.
Tried the synthitics, but it leaked to much out of the old gaskets.
Old May 31, 2003 | 06:19 AM
Mystery Machine's Avatar
Mystery Machine
Mobil 1 10-30 full synthetic. I have no idea if it's any better but I figured more expensive must mean better...right? :crazy:
Old May 31, 2003 | 07:29 AM
OkeeGuy's Avatar
OkeeGuy
Castrol GTX 10-30...tight, new engine
when engine gets older...20-50
i will never use synthetics again...
tried em twice...both times, cars developed leaks...
switched back, leaks stopped...
i have read many places that todays "crude" type oils are all about the same...
now filters...thats a different story...
nothing but the best for me...Mobil 1
look here to learn about filters... http://www.scuderiaciriani.com/rx7/oil_filter_study/
[Modified by SIGNGUY, 7:32 AM 5/31/2003]
To Oil?
