Broke the car doing a burnout
Old May 31, 2003 | 05:41 PM
VetticusSupersonicus's Avatar
Default Broke the car doing a burnout
So last night a friend and I are in a parking lot and I did a little burnout. Dropped the clutch at about 2500-3000rpm and promptly broke the car. It did the burnout, but right after that I notice that I can't let the clutch out without a terrible clanking sound. Even in neutral, as soon as I let the clutch out it will clank around until I push the clutch in again, at which point the sound fades away. It still drives forward, but it's sounding just awful.
I won't be able to take a look at it tomorrow, but does anyone have any idea of what might be broken?
Thanks. :cheers:
Old May 31, 2003 | 06:24 PM
blown454's Avatar
blown454
Default Re: Broke the car doing a burnout (VetticusSupersonicus)
It sounds like you broke or chipped a tooth on of one of the gears in the tranny. I did that in a Camaro that I had years ago & it had the same symptoms.
Old May 31, 2003 | 07:00 PM
Default Re: Broke the car doing a burnout (blown454)
Ugh. How much is it going to cost to fix that?
Old May 31, 2003 | 07:58 PM
QuickVet's Avatar
QuickVet
dont worry, A LOT :jester
Old May 31, 2003 | 08:14 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Broke the car doing a burnout (QuickVet)
:iagree: Sounds expensive to me, & I have a lot of experience with broken parts :cry
Old May 31, 2003 | 08:24 PM
FASGLAS's Avatar
FASGLAS
CI 4-5-6-7-8-9-10-11 Vet
St. Jude Donor '06-'07-'08-'09
:iagree: :yesnod: :yesnod:
Old May 31, 2003 | 08:47 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Broke the car doing a burnout (FASGLAS)
Damn, that sucks.
Old May 31, 2003 | 09:32 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
I see it's comedian nite! :D
Nothing worse than letting out the clutch(even in neutral) and a grinding sound. Well... maybe a rod slapping around inside the block is a little worse sounding.
Old May 31, 2003 | 10:48 PM
joe73vette's Avatar
joe73vette
Default Re: Broke the car doing a burnout (bgrice)
I agree, rod noises are the worst! Especially when they come after doing something immature and fun. :banghead: Joe
Old May 31, 2003 | 11:49 PM
Steve Straus's Avatar
Steve Straus
I wouldn't drive it, you'll only make it worse. This really does sound like a busted gear.
Old Jun 1, 2003 | 02:09 AM
Rockn-Roll's Avatar
Rockn-Roll
When you put the tranny in gear the cluster will stop spinning. So, if you put the tranny in neutral and let out the clutch to get the gears spinning, then put the clutch in and then shift into gear does the clanking suddenly stop? If so then it's the tranny, if not it could be the throw out bearing, cause when you let out the clutch the bearing will then be free to kick around. The bearing runs on a small extension of the front tranny cover. Sounds to me like your extension broke and the bearing is loose...I bet it's hard to put into gear too. I bought a used one at a shop near me for $5, and a gasket for $2.50 and my problem was solved...hopefully your problem will be just as easy.
I've broken gears too, and when you break a tooth or two you will not be able to smoothly drive forward or backward. So, it doesn't sound serious to me. But, I wouldn't drive it...have it towed home and drop the tranny to have a look.
Old Jun 1, 2003 | 02:46 AM
LAvetteman's Avatar
LAvetteman
Default Re: Broke the car doing a burnout (Rockn-Roll)
Is it just me, or is burnouts causing alot of grief here lately. :lolg:
Old Jun 1, 2003 | 02:53 AM
Double Aught's Avatar
Double Aught
Default Re: Broke the car doing a burnout (LAvetteman)
:rofl: First, a CI IV member rips up a parking lot and is invited not to return, now this. :lol: When will you kids learn?
Old Jun 1, 2003 | 04:05 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i agree with RnR. not saying it can't be the tranny but i think your looking more at throw-out bearing or pressure plate, maybe even clutch springs. you won't know until it comes out.
[Modified by clutchdust, 1:07 AM 6/1/2003]
Old Jun 1, 2003 | 04:28 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Broke the car doing a burnout (sd pacecar)
Never. :confused: :confused: :confused: :confused:
If that was the correct answer, what do I win. :lol:
Old Jun 1, 2003 | 08:39 AM
vincevette's Avatar
vincevette
I think rocknroll head the nail right on the head. It sounds more like a bearing than a gear to me. good luck :cheers:
To Broke the car doing a burnout
