wonky window
Old May 31, 2003 | 08:28 PM
mike_burtie's Avatar
mike_burtie
Default wonky window
Hi Guys,
Quick question - if the drivers side window on my 78 seems to take ages to wind up & even then, it doesn't go all the way to the top (Ihave to pull it up the last few inches), is that something to do with the motor, gears or what ? - the passenger side window works fine.
Anyone hazard as guess at to how much it's cost to fix, or what I need to look at first & the best way of getting to the gears, there doesn't seem to be much room in the door panel
cheers
Mike :flag
Old May 31, 2003 | 10:07 PM
isosceles's Avatar
isosceles
Default Re: wonky window (mike_burtie)
Don't know how to fix it.. but WONKY?! :rofl:
Old May 31, 2003 | 11:13 PM
Cookwithvette's Avatar
Cookwithvette
Default Re: wonky window (isosceles)
Isosceles, Never heard wonky bofore? You need to watch more British comedy. :yesnod: :lol:
Mike, Your window motor could be bad but I'd check other things first. Does the window misbehaive while the engine is running too? I once had two windows "stick" in the down position but it turned out to be a nearly flat battery. If the window does go all the way up (with manual aid) then your adjustments are okay you just might need to lubricate the tracks. If I were you I'd keep motor/gears as a last option. I replaced one motor and it was about $128 here in the 'States. Not as hard to do as it looks, there are only three bolts once you get the door panel and dust cover off. (at least on a 75. I wouldn't think it would be too different on a 78) I've heard white lithium grease is a good lube for window tracks. You can even get it in a spray can now.
Good luck! :cheers:
Old May 31, 2003 | 11:45 PM
isosceles's Avatar
isosceles
Default Re: wonky window (Cookwithvette)
I suppose so. I used to watch Monty Python( nudge nudge, say no more) , but don't remember that. So for now I guess it will be " on yer bike , Wally!" :jester I love British humor
Old Jun 1, 2003 | 01:36 AM
Cookwithvette
Not sure if you've heard of it before but if you come across a show called Red Dwarf... Worth watching. Probably my all-time favorite TV show.
Rimmer: Recommend going to red alert.
Kryten: Are you sure? It does mean changing the bulb.
Another scene...
Lister: What a Mickey Mouse operation we've got.
Cat: Mickey Mouse?! Hell! We ain't even Betty Boop.
:cheers:
To wonky window
