Rear Speakers installed, Pic???
Old May 31, 2003 | 10:01 PM
CF6873's Avatar
CF6873
Default Rear Speakers installed, Pic???
This is my first attempt at posting a pic. If it works it will be a pic of my Infinity 6x9's in my 73. This mount location takes no floor space. Craig
[Modified by CF6873, 10:07 PM 5/31/2003]
[Modified by CF6873, 10:12 PM 5/31/2003]
Old May 31, 2003 | 10:45 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Rear Speakers installed, Pic??? (CF6873)
Those look great what are you going to cover them with? :thumbs:
Old May 31, 2003 | 10:47 PM
mrbeaubo's Avatar
mrbeaubo
Did you make a speical box to fit into that corner or what? I'm looking to do the same exact thing and would love any info you have on what you did! Thanks.
Old May 31, 2003 | 11:35 PM
CF6873's Avatar
CF6873
Default Re: Rear Speakers installed, Pic??? (mrbeaubo)
Here is a pic of the plywood mount that I made. It is 3/4" thick and as you can see I attached a metal bracket that bolts through to the inner fender well. On the rear edge I installed plastic screw anchors in the plywood and ran the screws in from under the car in the rear panel. If you need more info I will try to help. Craig
:cheers:
Old May 31, 2003 | 11:39 PM
mrbeaubo's Avatar
mrbeaubo
Thanks! I will let you know if I need some more help when the time comes to do that :)
Old May 31, 2003 | 11:55 PM
DMONSVETTE's Avatar
DMONSVETTE
Hey, that looks pretty good, thanks for sharing the idea. :thumbs:
To Rear Speakers installed, Pic???
