Ok folks, after all the sage advice on my brakes, (which mind you, i can now stop on a sime and give ya 20 cents back!) the next focus of concern is my right side cowl drain... I have had a slight problem with getting water on the right side floor board. I took the right side kick panel off and had a buddy pour some water slowly down the winshield post and got some water in. I allowed the area to dry out good and inspected the windshield area at the bottom. I did see some small holes which I then sealed up with black silicone and that stopped 90% of it. My gut instinct tells me that the cowl drain may be plugged. Whats the best way to clean them out????
You may also want to check the rubber seal where the windshield and fender meet... http://users.erols.com/jerryp58/corv.../vetteseal.JPG You could put a small bead of caulk on it or even tape it to see if the leak is coming from there.
