I am doing the valve seals on the L-82 and while I am in there messing around I was wondering id the Comp Cams 1.52 roller tip rockers would be worth the $150. My stock arms look beat so at the least I am going to replace them with something. Help
Re: Are Comp Cams 1.52 roller tips worth it? (MotorHead)
I am running them on my car and have had no problems wit hthem. They are very good rockers for your application. They will also fit under the stock valve covers
Re: Are Comp Cams 1.52 roller tips worth it? (Xracer)
I would spend the extra $ and go full roller. I am running 1.6 full rollers under stock covers with double gaskets. You can get single thick gasket but I had 2 sets fo the reg laying around so I used them. BTW Summit brand full rollers ae only $160.
I have a set of Crane roller tip 1.6 rockers and locking nuts you can have for $100.
