Roller Rockers
Old Jun 2, 2003 | 12:25 PM
Glutamine83's Avatar
Glutamine83
Default Roller Rockers
if I upgrade from a factory rocker system to roller rockers (1.6), what kind of horsepower can I expect to gain? at what RPM? what brand of rockers should I buy?
Old Jun 2, 2003 | 12:40 PM
Fevre's Avatar
Fevre
Default Re: Roller Rockers (Glutamine83)
You will see some hp gains from the reduced friction and you might see some with the increased lift IF you heads flow well in the new lift range. Probably 10 to 30 in best case. Might also helps reduce eng oil temp a touch with the reduced friction. Make sure your springs are matched to the new lift or you will have binding.
