Question about a switch
Old Jun 3, 2003 | 12:33 AM
75 Stingray!'s Avatar
75 Stingray!
Default Question about a switch
I was wondering what this switch does. At first I thought this was an aftermarket switch and set it to the center position thinking it was off, I had planed to follow the wires at a latter date. Recently I was looking on ebay at 75 corvettes for sale and noticed another one with the exact same switch so hopefully you guys can help me. Another thing, how do I remove the horn button? I want to correct my emblem, do I simply pull it off or do I have to twist and pull? Thanks guys for your help
Old Jun 3, 2003 | 12:42 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
Default Re: Question about a switch (75 Stingray!)
That is a two speed rocker switch for the rear window defroster(or defogger) behind the driver's seat, in the left rear roof pillar. It is off when centered. Yes, your horn button just "clicks" or snaps on. Goes back on the same way, it will just blow the horn while you are pushing it back on, until you let up.
Old Jun 3, 2003 | 12:57 AM
75 Stingray!
Default Re: Question about a switch (Paul Borowski)
Thank you for the help Paul Borowski :thumbs:
To Question about a switch
