383 VS 396!
Old Jun 3, 2003 | 03:08 AM
sharkthehunter77's Avatar
sharkthehunter77
Default 383 VS 396!
I pretty much get the point that a 383 is an overbored .030 350 with some block modifications and a 400 crank. What i dont understand is the 396. As in what is done to produce one and is it considered a big block. How much is the block bored out for that type of stroker, Do you still utilize a 400 crank? Both require complete balancing of the rotating assembly right? What else has to be done for this type of project to work?
Old Jun 3, 2003 | 04:49 AM
2BAD's Avatar
2BAD
Default Re: 383 VS 396! (sharkthehunter77)
A 396 is stroker with 3.875" stroke(400 is 3.75) and 4.040 bore.
If you bore it to 4.060 you'll get 401 :thumbs: and it's not a big block, simply because you are using a small block chevy BLOCK !
Of course since you are using new pistons,rods, and crank you have to get the rotating assemply balanced .
:seeya
Old Jun 3, 2003 | 04:54 AM
442olds's Avatar
442olds
Are you trying to stroke a small block out to 396 or are you wanting to build a big block 396. There is a difference.
To make a 396 out of a small block your looking at a 4.1" bore (+.100) with a 3.75" stroke (400 crank).
Factory 396 Big Blocks use a 4.09 bore and a 3.76" stroke crank.
If you plan on building a motor with a butt load of torque and the potiential to hit the high r's I suggest the Big Block 396 over the stroker small block. But then I am kinda partial to a Big Block.
383 kits for the small block are readily avaiable and are much easier to come by than the 396 kits and the 396 big blocks are getting harder and more expensive by the day. The 383's can make just as much power as a lot of big blocks out there and I doubt you'd see that much difference between the 383 and 396 small block stroker motors
Old Jun 3, 2003 | 04:58 AM
2BAD's Avatar
2BAD
Yeah, what else !
I didn't read about any 3.875 cank that requires external balancing(like a 400), but if so you'll need a flywheel and balancer of a 400 .
And yes, you'll need to heavily notch the block to clear that loooong stroke !
Old Jun 3, 2003 | 05:05 AM
2BAD's Avatar
2BAD
Default Re: 383 VS 396! (442olds)
:blueangel:
Please when the last time you saw someone doing a 396 BBC stroker !
I prefer the small block due to the weight saving -I think about 200 lb.
4.1" bore = aftermarket block = BIG $$$$$$ :seeya
Old Jun 3, 2003 | 03:38 PM
ry's Avatar
ry
Default Re: 383 VS 396! (2BAD)
Does anyone know how much a stroker runs now-a-days? $$
Old Jun 3, 2003 | 04:39 PM
BB73Chris's Avatar
BB73Chris
:blueangel:
A 396 BBC is not a stroker, it's a factory engine used in everything from vettes to trucks in the mid/late 60s. There's a pic of one in my sig. A "396 stroker" is a smallblock.
Just my opinion, but it seems if you're going to use a 400 stroke, then bore your 350 block out to within .025 of a 400 bore, spend lots of money, and end up within 4 inches of a 400, why didn't you just build a 400? they're not all that hard to find, and big main journals seems like a good idea as well as siamese bores that give you more than a paperswidth of cylinder wall.
Old Jun 3, 2003 | 04:47 PM
JJ Deuce's Avatar
JJ Deuce
Default Re: 383 VS 396! (BB73Chris)
not to hijack, but did anybody else see the World Products 454 small block in this month's Hot Rod magazine? :cool:
Old Jun 3, 2003 | 04:52 PM
Tominator's Avatar
Tominator
Default Re: 383 VS 396! (Jeff 6T9)
Sharkthehunter77; haven't checked the price of stroker kits latley but it seemed like the 383 & 396 kit were about the same.
Jeff6T9; yea isn't that killer and a 2 year warranty, them boys must really be confident to offer a warrant on a 600 hp engine (think that's what it was)
Although theres something about a sb 427 that tickles me too. :D :cheers:
[Modified by Tominator, 3:53 PM 6/3/2003]
Old Jun 3, 2003 | 04:59 PM
gkull's Avatar
gkull
It cost the same to build a 396 ci small block (4.030X3.875) as a 383 ci (4.030X3.75)
IMO the 396 is the only way to go. Don't even think in terms of 400 crank in a 350 block and bore that was 20 years technology. You can buy all quality parts in kit's depending on how thick your wallet is.
Another alternative is the 408 ci 4.030X4.00. One of the guys here on the forum owns a ATI centrifical blower one that dynos at over 600 RWHP.
I have built a few stroker motors and that's all I'll ever build again.
Old Jun 3, 2003 | 05:02 PM
Tominator's Avatar
Tominator
Default Re: 383 VS 396! (gkull)
The 408 is that a 400 block?
Old Jun 3, 2003 | 06:52 PM
gkull's Avatar
gkull
Default Re: 383 VS 396! (Tominator)
How do I say it? Read my lips! Another alternative is the 408 ci 4.030X4.00.
4 inch stroke in 350 blocks requires epoxy filled lower block in the water jackets and splayed caps to hold the bottom of the motor together. Personaly I would not make one although I've considered it.
Old Jun 3, 2003 | 07:11 PM
PatsLs1vette's Avatar
PatsLs1vette
or just go for the gusto and get a dart iron eagle block and build a small block 481 :yesnod: :D
http://www.speedomotive.com/SB%20CHE...RANK%20KIT.htm
Old Jun 3, 2003 | 07:14 PM
A C's Avatar
A C
Cruise-In II Veteran
That was a pretty cool motor, but one thing I didn't see in the article was the price. Did anyone see that? :confused:
AC
Old Jun 3, 2003 | 07:20 PM
Never Finished's Avatar
Never Finished
The 454 is around $10k. Five hundred more for aluminum heads. The aluminum head version has a solid lifter cam.
Old Jun 3, 2003 | 10:05 PM
69vette66's Avatar
69vette66
Default Re: 383 VS 396! (ry)
I have a 421 small block stroker, and lots of machine work and lots of grinding to make the long rods clear the block. I have around $4500 in mine, That top to bottom, since I did most of the work myself. The lower end, crank, rods, and pistons, cost the bucks, plus the machine work.
:cheers: Larry
To 383 VS 396!
