rear axle ratio - quick method to determine?
Old Jun 3, 2003 | 12:49 PM
Mike Mercury's Avatar
Mike Mercury
Default rear axle ratio - quick method to determine?
I'm not so sure that the wifes 1973 has a factory rear axle ratio. Although the speedometer is within 2mph of my '02; I am not convinced the car has the original ratio.
Is there a quick method to determine this ratio (like there is on a C5) ?
Old Jun 3, 2003 | 12:57 PM
Tex71BB's Avatar
Tex71BB
Default Re: rear axle ratio - quick method to determine? (Mike Mercury)
Best way I know is the direct method: jack up the rear, put marks on the driveshaft and wheel, and see how many turns of the driveshaft you get with one turn of the wheel.
Old Jun 3, 2003 | 01:16 PM
79VetteMike's Avatar
79VetteMike
Default Re: rear axle ratio - quick method to determine? (Tex71BB)
:iagree:
Old Jun 3, 2003 | 01:32 PM
Tominator's Avatar
Tominator
Another way is use the calculator at this web site http://www.prestage.com/carmath/calc_gears.asp
You will need the following info RPM, mph, tire height
Old Jun 3, 2003 | 05:30 PM
Mike Mercury
Default Re: rear axle ratio - quick method to determine? (Tominator)
Tominator, I've seen that one before. I know it works on automatics that have lock-up torque convertors; but how would you figure in TC slip on the older cars?
Old Jun 3, 2003 | 05:47 PM
Tominator's Avatar
Tominator
That is a good question, I did mine with a rebuilt tranny and nonstock stall convertor 1800 - 2200 Summit brand and it was on the money. My understanding is once your convertor gets to a certain rpm it's locked or close to it.
The reason high stall convertors cuase so much driving around town is they're slipping, like if you had a 3500 stall and were driving around town at 2000 rpm it would be slipping.
At higher speed you should be good to check the speed and RPM.
Old Jun 4, 2003 | 01:58 AM
tnt76vette's Avatar
tnt76vette
Another site U can try is http://www.smokemup.com. With a 3.55 rear end, I am turnin' 3K rpm @ 70mph.......... :cheers:
Old Jun 4, 2003 | 04:54 AM
mrvette's Avatar
mrvette
ANY converter will have a 3-400 rpm slippage in there at any speed, like say a 400, hop on and off the gas at say 80 mph....yeh, it slips....
you have NO way to verify your speed or rpm's to an absolute to effectively use any formula....so forget about that approach...
best thing is just carefully count the rotations as stated before...
GENE
Old Jun 4, 2003 | 09:28 AM
Tominator's Avatar
Tominator
Default Re: rear axle ratio - quick method to determine? (mrvette)
The calculator method may not be perfect due to slipage, however it is good enough to determine your gears.
If you hold a constant speed say 55 and then run the number through one of the calculators and it comes out to 3.51 or a 3.59 rear gear. At this point you can deduct it's a 3.55 rear end. IMHO
Old Jun 4, 2003 | 09:39 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:iagree:
Old Jun 4, 2003 | 10:08 AM
tnt76vette's Avatar
tnt76vette
:iagree: And its one HECK of alot simpler, cleaner, etc.
Old Jun 4, 2003 | 10:15 AM
bbeck's Avatar
bbeck
Default Re: rear axle ratio - quick method to determine? (GrandSportC3)
:iagree:
:iagree: As the other way, from what I've read, you must know the MPH. Well, unless you have a reliable, outer source reading your speed. If the rear gears have been changed, or diff height tires are being run, you're not sure of your speed.
Old Jun 4, 2003 | 10:17 AM
MikeM's Avatar
MikeM
Default Re: rear axle ratio - quick method to determine? (tnt76vette)
If you do not have posi-traction, jack up one wheel, turn one revolution and multipy the driveshaft revolutions by two=ratio.
If you do have posi-tracion, jack up both wheels. Make sure both rear wheels turn one revolution. The revolutions turned by the driveshaft will = ratio.
Mike :)
To rear axle ratio - quick method to determine?
