Tail Lights ALWAYS on
Old Jun 3, 2003 | 10:50 PM
azswede1960's Avatar
azswede1960
Default Tail Lights ALWAYS on
Whenever I engage battery power, the tail-lights come on, even though the headlights are off. Anybody have any ideas to troubleshoot this problem ?
Old Jun 3, 2003 | 11:00 PM
stingray72's Avatar
stingray72
Default Re: Tail Lights ALWAYS on (azswede1960)
You didn't say what year your car was, but if its the TAILLIGHTS, I would say the headlight switch is shorted out internally. If its the BRAKE LIGHTS, then my guess would be a bad brake light switch. I am assuming the car's wiring is in good condition.
George
Old Jun 4, 2003 | 12:07 AM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: Tail Lights ALWAYS on (stingray72)
:iagree: :iagree: :iagree:
Check the brake light switch.
Old Jun 4, 2003 | 12:44 AM
azswede1960
Default Re: Tail Lights ALWAYS on (Greg)
It is a 1980. If I turn on signal (either right or left, that light goes out completely) and if I turn flashers on, both lights go out.
Also if I turn on headlights, the tail-lights DO NOT come on.
Old Jun 4, 2003 | 03:16 AM
bbeck's Avatar
bbeck
:iagree:
almost for sure it's the brake light switch. I had the same thing in my dad's nova, just like you explained. Try adjusting the switch, first, as that's what I did and it worked. -It wasn't even touching the pedal for some reason..?? If not that, try unplugging the switch, that should disengage the brake lights. I imagine you know where the switch is? Good luck, it shouldn't be too hard to figure out.
To Tail Lights ALWAYS on
