Smooking 75 after start-up when Hot
Old Jun 4, 2003 | 03:19 PM
vette_c5c6's Avatar
vette_c5c6
Default Smooking 75 after start-up when Hot
What is happening? When I start the 75-L48 in the mornings NO smoke at the exhaust. But when I restart the vette when hot it smokes real bad for abought 15 seconds then is clears-up and away I go. I also noticed it needs 1 quart of oil every 1,000 miles ( note slight oil leak) So what is wrong.
Old Jun 4, 2003 | 03:37 PM
Bobchad's Avatar
Bobchad
Default Re: Smooking 75 after start-up when Hot (vette_c5c6)
I suspect that the smoke is from valve stem seals. Mine does the same thing though I don't have to add any oil. How bad is your leak? Have you done the appropriate compression checks?
