While my motor's out...?
Old Jun 4, 2003 | 07:42 PM
Sun King's Avatar
Sun King
Default While my motor's out...?
What else should I be replacing while doing the engine swap? Tranny and steering rack are done. I plan to have the radiator rebuilt and will re-paint the compartment, replace the coolant reservoir and front suspension.
What am I missing that's easiest to do at that time? :lurk:
ps I'm dropping in a 300 hp longblock from Power2000.
Old Jun 4, 2003 | 08:12 PM
DougsL89's Avatar
DougsL89
Default Re: While my motor's out...? (WS6TA01)
I would do:
(1) Clutch replacement.
(2) Check engine wiring harness for burnt/spliced connections and brittleness. For only $165, it is worth replacing. I can't believe my car did not burn to the ground with what I found on mine.
(3) Leak-check vacuum reservoir tank with hand-held vacuum tester.
(4) Check all clutch linkage for worn parts.
(5) Install any missing insulation (trans tunnel and bellhousing collar).
Old Jun 4, 2003 | 09:17 PM
Boofers's Avatar
Boofers
Take lots of pictures :thumbs:
Old Jun 4, 2003 | 09:22 PM
BB73Chris's Avatar
BB73Chris
Where did you get the engine? my browser can't seem to find Power2000.com (as you called it in another post) :confused:
Old Jun 4, 2003 | 09:38 PM
OkeeGuy's Avatar
OkeeGuy
just thought i would let you that if your radiator is very bad, i have a brand new one (3000 miles on it)...
IM me if your interested in it...
good luck with your project...i just spent 5-1/2 months doin it...
heres a link... http://signguy.freeservers.com/photo.html
it was a hell of a lot of work...
it is one of those "while im at it" jobs...
Old Jun 5, 2003 | 08:37 AM
Sun King's Avatar
Sun King
Default Re: While my motor's out...? (DougsL89)
I would do:
Thanks, that's the kind of info I'm looking for. I'll do the new harness. Clutch and everything is done.
Chris here's the link http://www.powerpro2000.com Their prices/warranty is hard to beat.
Old Jun 5, 2003 | 08:48 AM
vettfixr's Avatar
vettfixr
The biggest thing I would recommend doing with the engine out is to rebuild the heater box. This is almost impossible to remove once the engine is in but a real snap if you have the clearance. I did mine with the engine in and it took way longer. Check out Doc Rebuild for the rebuild kit.
Old Jun 5, 2003 | 12:36 PM
zymurgist's Avatar
zymurgist
Replace all the ball joints, idler arm, etc. (I had my steering box rebuilt also but you mentioned a rack.)
Replace the rag joint.
Install new brake lines (both hard and flexible).
Rebuild or replace master cylinder.
Replace vacuum lines for headlight mechanisms.
Re-wrap the wiring harness.
Replace all radiator and heater hoses and heater control valve.
Powder coat every pulley, bracket, etc. that you can get loose.
Don't add up the receipts until 6 months after you're done. :crazy:
(BTDT)
Old Jun 5, 2003 | 06:43 PM
Sun King's Avatar
Sun King
Default Re: While my motor's out...? (zymurgist)
(BTDT)
:eek: :eek: :eek: ...but thanks!!!
To While my motor's out...?
