The best radiator flush
Old Jun 4, 2003 | 09:40 PM
73jst4fun's Avatar
73jst4fun
Default The best radiator flush
I was wondering what Forum members have used in flushing a radiator to remove visible deposits inside and around the flow tubes
Thanks for your imput... :)
Old Jun 5, 2003 | 07:13 AM
Gary79's Avatar
Gary79
Default Re: The best radiator flush (73jst4fun)
couple scoops of dishwasher soap, fill'er up with water and go drive for about 25 miles. let'er cool off and drain it, pull your block plugs to get the water out of the block.
Old Jun 5, 2003 | 08:58 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default Re: The best radiator flush (Gary79)
:iagree:
Make sure you use the stuff for automatic dishwashers, NOT dishwashing detergent.
Old Jun 5, 2003 | 10:58 PM
73jst4fun's Avatar
73jst4fun
Default Re: The best radiator flush (6t9l4t6)
Two or three scoops (what are we talking here about 1/2 measured cup, tablespoon?) of the automatic dishwasher powder should be enough? and that removes the build up around the flow tubes?
Thanks guys... :)
[Modified by 73jst4fun, 4:02 AM 6/6/2003]
Old Jun 6, 2003 | 01:49 AM
tnt76vette's Avatar
tnt76vette
And what degree Stat should be used when doing this? Or should the Stat come out? Inquiring minds want to know........ :confused:
Old Jun 6, 2003 | 03:21 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: The best radiator flush (tnt76vette)
I wouldn't use dishwashing liquid or powder. You may never get all of it out.
Besides, it's made for china and glass not aluminum, brass, steel and rubber.
I would use something made for flushing the radiator, something like Prestone cleaner.
Old Jun 6, 2003 | 04:02 AM
fst_c3's Avatar
fst_c3
I have used nothing but distilled water/coolant in mine. It still looks like new inside after 7 years.
To The best radiator flush
