Making the T Bar Pretty
Old Jun 5, 2003 | 08:42 AM
Mystery Machine's Avatar
Mystery Machine
Default Making the T Bar Pretty
The T bar on my car is aluminum (I think) and it looks terrible, it's all cloudy looking and I was wondering if anyone knows if there is a cover that you can put on it...maybe something chrome. Or, is there a polish that will clean it up? I've tried both Mothers aluminum polish and chrome polish and it still looks awful.
Thanks! :thumbs:
Old Jun 5, 2003 | 08:44 AM
Sun King's Avatar
Sun King
Default Re: Making the T Bar Pretty (Mystery Machine)
I use a little 3M hand glaze on mine and rubb it out. Looks like new. :thumbs:
Old Jun 5, 2003 | 08:46 AM
vettfixr's Avatar
vettfixr
I believe the T-bar is made of stainless so the polishes you're using won't do much to bring up the shine. You have to remove the bar and then polish it on a buffing wheel. If I were going to give it a try I would first wet sand the entire bar with 2000 to 3000 wet sandpaper and then buff it with 2 or 3 succeedingly finer compounds. You can check out places like Eastwood for their stainless buffing kits or I'm sure many others on the web. It's not an easy job so you might just look into a replacement if it bothers you that much. Good luck.
Old Jun 5, 2003 | 08:51 AM
Neo Fender's Avatar
Neo Fender
I've had good results with Nevr Dull.
Old Jun 5, 2003 | 08:54 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
The T-bar is stainless steel. You can remove it and use a buffing wheel and compund but be very careful. It is sharp and also bends very easily. You might want to try buffing it without removing it from the car. If you still don't like it it can be replaced but make sure you get the correct year. The rear "extensions" on the early models (1968 - 1973) are about 1/2" longer on each side than later models. I don't think they are available through any repro dealers.
Old Jun 5, 2003 | 10:01 AM
87bob's Avatar
87bob
Veteran: Coast Guard
Hey what about covering up the interior and using a drill mounted buffer like a wheel buff and compound from Eastwood. Done gentlely enough you wouldn't run the risk of bending it out of shape or snagging it. Run the buff so it would slip over the edge as you get to it and not grab.
Old Jun 5, 2003 | 10:11 AM
Mystery Machine
Default Re: Making the T Bar Pretty (87bob)
Great suggestions guys! Thanks! :thumbs:
Old Jun 5, 2003 | 02:11 PM
jrzvette's Avatar
jrzvette
You could also leave the T-Tops on. Hell if you wanted a convertable you should have bought one!!! :jester :jester :jester
Old Jun 5, 2003 | 02:29 PM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I am planning on doing mine this weekend. My approach is to cover the intereior and buff it using Eastwood S/S buffing compound on a 3" buffing wheel on a drill.
Old Jun 5, 2003 | 08:03 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default Re: Making the T Bar Pretty (gliot1)
Some fine steel wool, like OOOO grit, works wonders on the stainless. Use a little metal polish like Autosol with it and you will get outstanding results.
Old Jun 6, 2003 | 02:32 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Making the T Bar Pretty (7t2vette)
http://forums.corvetteforum.com/zerothread?id=504081
If you need more info, just IM Cali,77,L-82
:cool:
Old Jun 6, 2003 | 02:41 AM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Making the T Bar Pretty (6t9l4t6)
If mine ever has to come off it will get powder coated red and that will be the end of those problems.
Old Jun 6, 2003 | 05:57 AM
Mystery Machine
Default Re: Making the T Bar Pretty (BSeery)
That would look killer! :thumbs:
Old Jun 6, 2003 | 02:54 PM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Default Re: Making the T Bar Pretty (WS6TA01)
:leaving:
You said hand glaze and rub it out in the same sentence :crazy:
Old Jun 6, 2003 | 02:56 PM
SnoDrgn's Avatar
SnoDrgn
Damn... I wish I could get mine to look this good
Old Jun 6, 2003 | 03:12 PM
Let 'er eat!'s Avatar
Let 'er eat!
Mystery -
I have an extra T bar in the garage - if you want to get it chromed I'll take your old one when you install it....
Old Jun 7, 2003 | 01:05 AM
CharlieF's Avatar
CharlieF
My bar is in good shape but the screws holding it in are either missing or the philips slots are stripped. Does any one know the size (thread) and length of said screws? or where I can purchase some.....I've looked in all my catalogs and it seems no one lists them.
TIA
Chas :flag
[Modified by CharlieF, 1:14 AM 6/7/2003]
To Making the T Bar Pretty
