Quick speaker wiring question
Old Jun 5, 2003 | 08:01 PM
Justin79-L-82's Avatar
Justin79-L-82
Default Quick speaker wiring question
When you are soddering the wiring harness to the speaker wires, there are two different wires for each speaker and the wiring harness, which one is the colored one, and which one is the same colored one but with the black stripe down it? Which is positive which is negative? And for speakers is the bigger pole positive and the littler one negative?
Old Jun 5, 2003 | 08:09 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Re: Quick speaker wiring question (Justin79-L-82)
I'll bet the guys at Best Buy or what ever electroinics store you have near you could answer that question.
Old Jun 5, 2003 | 08:55 PM
Bobchad's Avatar
Bobchad
Default Re: Quick speaker wiring question (87bob)
I've been told that the one with the white stripe is the positive.
Old Jun 5, 2003 | 09:07 PM
69shark's Avatar
69shark
From: Godspeed Mikey Hogsmak Invitational Spring Skyline Drive Corvette Cruise
Cruise-In I Veteran
Cruise-In II Veteran
Justin, different manufacturers do things differently so I couldn't tell you exactly but the positive and negative lead are really for correct phasing. What you need to do is make sure all are the same, that is if you put the wires for left, right, front, rear etc with the black stripe to the small connector on the speaker all speakers will be phased correctly. Phasing is when the voce coil of the speaker is moving in the same direction on all speakers at the same time. Let's say a positive voltage across the coil cause the coil to move out on the magnet, you want all to move so the sound wave are being pushed in the same direction. For example if you have two speakers pointed at each other and they are out of phase when one speaker is moving out the other would be moving in and you would be cancelling out the sound of each speaker. But as an educated guess( I do commercial sound) I would tend to assume the large spade lug on the speaker is positive and the leads with a black stripe are negative. :cheers:
Old Jun 6, 2003 | 03:32 AM
ry's Avatar
ry
just use a multi-meter. best darn investment i ever made
Old Jun 6, 2003 | 04:01 AM
Rockn-Roll's Avatar
Rockn-Roll
Default Re: Quick speaker wiring question (69shark)
:iagree: I've been in the music business before and built my own cabinets and stuff...usually the black with white stripe wire is positive. But like 69shark said it doesn't matter THAT much, as long as you do all the speakers the same. The only time it REALLY mattered was pre 70's and some early 70's when the speakers were connected to the output transistors via a transformer or when the speakers were directly connected with a load resistor in series to limit the voltage. So...are you wiring up a stock system, or is it a new system?
Old Jun 6, 2003 | 10:15 AM
Justin79-L-82
Default Re: Quick speaker wiring question (Rockn-Roll)
I'm wiring an aftermarket system, new cdplayer, and new front and rear speakers. When i installed it last year it had terrible bass response so i took it apart last night and found that one of the rear speakers was wired wrong, so i took out all the stock wire and put in some 16 guage, and made sure everything was routed the same. Thanks for the info guys, it sounds alot better now
Old Jun 7, 2003 | 03:01 PM
The Money Pit's Avatar
The Money Pit
I agree with trying to phase your speakers for postarirty sake,but would like to meet the guy who can actually hear a speaker that is out of phase.We're talking nit picker here.
To Quick speaker wiring question
