I have??????
Old Jun 6, 2003 | 09:34 AM
69Sting's Avatar
69Sting
Default I have??????
Knowing that the motor in my care was changed, but I was told when I bought the car the new motor was the same as original. Originaly the car came with the 350/350 L46.
When I looked at the numbers on the block I did not see L46 anywhere. I say 388 by the water pump and this number on the left rear bank GM 3932388. Can anyone help me out in finding out what motor this is?
Also where can I go to find out what the numbers in the vin mean?
Thanks for the help..
Old Jun 6, 2003 | 12:19 PM
mayberg's Avatar
mayberg
Default Re: I have?????? (69Sting)
You wouldn't see L46 on the block itself. This was simply an RPO code for the assembly line and window sticker.
It very well could be that the block number you specified pertains to a 69 L46 motor, and it could have other applications as well. I don't think that the block itself means you have an L46 - there's heads, intake, cam, etc. that go into the combination.
In order to decipher numbers, you might consider picking up the Corvette Black Book, or pick up the technical reference manual for the 1969 Corvette from NCRS. You might also consider posting this over in Factory Correct Resto.
Old Jun 6, 2003 | 12:35 PM
tnt76vette's Avatar
tnt76vette
Default Re: I have?????? (mayberg)
[/QUOTE)
In order to decipher numbers, you might consider picking up the Corvette Black Book, or pick up the technical reference manual for the 1969 Corvette from NCRS. You might also consider posting this over in Factory Correct Resto.[/QUOTE] :iagree:
Old Jun 6, 2003 | 09:42 PM
BB73Chris's Avatar
BB73Chris
According to http://www.mortec.com that number is a 1969 350 with 2 or 4 bolt mains and it doesn't say anything else. If you have the front stamp number you could find out more........
EDIT: guess ya can't put commas after urls...
[Modified by BB73Chris, 8:43 PM 6/6/2003]
Old Jun 6, 2003 | 10:44 PM
Greg's Avatar
Greg
Just another Corvette guy
Default Re: I have?????? (BB73Chris)
Hey Nathan,
Nice looking car. The numbers you want are stamped onto a flat surface of the block, just below the front of the passenger side cylinder head. There should be two different series of numbers there. One is all numbers, the other a combination of alpha-numeric. Get both and post them here. I, or someone here will be glad to break it down for you.
Good luck, Greg
Old Jun 6, 2003 | 11:04 PM
Detroit Vette's Avatar
Detroit Vette
Default Re: I have?????? (Greg)
:iagree:
Old Jun 6, 2003 | 11:24 PM
69Sting's Avatar
69Sting
I will look for the number and post them on this string Sat afternoon sometime.
Thanks for the advice.
Old Jun 6, 2003 | 11:31 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Get the head casting numbers in the valve spring area....might help to identify the L-46 heads.
To I have??????
