Water Wetter?
Old Jun 6, 2003 | 01:34 PM
Glutamine83's Avatar
Glutamine83
Default Water Wetter?
can you buy water wetter in canada? does Canuck Tire carry it? I'm at work and I haven't had a chance to run down there and check
Old Jun 6, 2003 | 01:37 PM
midwest-vette's Avatar
midwest-vette
Default Re: Water Wetter? (Glutamine83)
Don't know about where it's available up there. But, I know it lowered my temps around 8*.
:seeya
Old Jun 6, 2003 | 04:35 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
You can order it at Summitracing.com... I'm sure that they ship to Canada...
Old Jun 6, 2003 | 05:13 PM
bloodvette80's Avatar
bloodvette80
Default Re: Water Wetter? (GrandSportC3)
drain fluid and fill with nitromethane, your engine concerns will no longer be a problem, promise. jk :)
Old Jun 7, 2003 | 01:11 AM
isosceles's Avatar
isosceles
does that stuff inhibit freezing? If not are you going back to glycol coolant in the fall?
I've been following some threads on Stewart components web site and they advocate running water + rust inhibitor from Prestone or Zerex. I'm doing it and along with their pump I'm running 30-40 degrees cooler.
Old Jun 8, 2003 | 11:24 PM
vettenoir's Avatar
vettenoir
Check out this link: http://clik.to/raceparts
They sell Water Wetter in Canada. I don't know what shipping to MB would cost, but you would avoid duty & brokerage from Summit. I'm running Water Wetter with about 25% antifreeze & 75% water. I can't say for sure how much cooler the engine runs, as I made a few other modifications at the same time. I drove the car all winter as long as there was no snow/no salt on the roads. The car is parked in an attached garage, and I haven't had any problems with freezing in southern Ontario. That said, you get MUCH colder winters than we do. Good luck.
To Water Wetter?
