Smog time
Old Jun 6, 2003 | 08:31 PM
HcDave1's Avatar
HcDave1
Default Smog time
i need to get my tags redone they were good till may oops where did that month go.
anyone got anything to point out before i go in and get it smoged?
Old Jun 6, 2003 | 10:32 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: Smog time (HcDave1)
Make sure that it's in good tune. If it is and you haven't made any obvious mods, you should be just fine.
Old Jun 6, 2003 | 11:05 PM
timbo79's Avatar
timbo79
Make sure heat riser tube is attached as well as crankcase breather to the Air Filter Housing. They will also check your timing to insure it matches your sticker: (silveer, above the brake booster setup by hood spring)
Also check your hoses to your AIR rails, as well as smog pump pulley.
Good Luck
To Smog time
