Trans wont shift into drive
Old Jun 7, 2003 | 02:00 AM
JohnG76's Avatar
JohnG76
Default Trans wont shift into drive
ok so after 3 years of sitting, the car finally fired up today, needs some timing adjustments and such, so i tried to take it out for a spin, put it into reverse, backed out fine, threw it into drive, no good, andy ideas?
Old Jun 7, 2003 | 02:32 AM
Schmucker's Avatar
Schmucker
Default Re: Trans wont shift into drive (JohnG76)
Did you crawl under the car and make sure that it was shifting on the transmission?
Old Jun 7, 2003 | 03:06 AM
JohnG76's Avatar
JohnG76
nah, but i felt the rear end kindof drop as i shifted into drive a couple times, tried 3-2-1
Old Jun 7, 2003 | 01:37 PM
JohnG76's Avatar
JohnG76
Does anyone know how much trans fluid is suppose to fit into a 350th thats been totaly drained? i've put in 4, ran the car, checked the dip stick, and appears to be bone dry, let me check the garage floor
To Trans wont shift into drive
