Need tire size suggestions.......
Old Jun 7, 2003 | 08:58 PM
Ryan77's Avatar
Ryan77
Default Need tire size suggestions.......
I put new BFG Radial T/A's (225/70R15) on the front of my vette last year, and plan to replace the rear's soon. But, I would like to go a little wider than a 225 tire. What are my options? I don't want it rub or stick out past the fender flares, in other words what is the biggest I can go without any chance of a problem? Thanks in advance :cheers:
[Modified by Ryan77, 8:59 PM 6/7/2003]
Old Jun 7, 2003 | 09:18 PM
shotgun_000's Avatar
shotgun_000
Default Re: Need tire size suggestions....... (Ryan77)
I'm running a P255 60R15 all the way around, with no problem. I think a P255 is about as wide as you can run, without modifications, or the tires sticking out.
Old Jun 8, 2003 | 07:49 AM
jerryp58's Avatar
jerryp58
I currently have 245/60-15s (front & back) with no clearance problems.
255/60s are supposed to fit, but some have clearance problems with the parking brake cable bracket. I'm going to try 255s soon and if the bracket is too close I'll either grind it down or have a shop move it over (they can pull it and weld it) until it clears.
Others have gone much bigger than that, but I'm not sure what mods they've had to make.
Old Jun 8, 2003 | 07:53 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Default Re: Need tire size suggestions....... (jerryp58)
Jerry, I put P255/60R15's all the way around with stock trailing arms. P255's were the option for the 81' year..guess the performance option, versus the P225/70R15. Have good clearance with no rubbing...hope this helps! :)
Old Jun 8, 2003 | 09:39 AM
Ganey's Avatar
Ganey
255/60/15 fit fine in rear.
Old Jun 8, 2003 | 09:43 AM
79VetteMike's Avatar
79VetteMike
I have 275/60/15's on the back with no mods.
Old Jun 8, 2003 | 09:55 AM
Skeets's Avatar
Skeets
I've got 275's on the back og my '79, no prob's .... i would guess they'd fit a '77 as well?
Old Jun 8, 2003 | 01:47 PM
Ryan77's Avatar
Ryan77
Default Re: Need tire size suggestions....... (Skeets)
Thanks for the replies, I think I'm going to go with the 255/70R15 on the rear :cheers:
Old Jun 8, 2003 | 03:09 PM
jerryp58's Avatar
jerryp58
" I think I'm going to go with the 255/70R15 on the rear "
Do you mean 255/60R15 ?
1. 225 * .7 = 157.5
2. 255 * .6 = 153.0
3. 255 * .7 = 178.5
1 & 2 are about the same height sidewall.
I don't know if anyone is running 3 (that's about 2" taller than stock) or if there would be clearance problems with it.
[Modified by jerryp58, 3:11 PM 6/8/2003]
Old Jun 8, 2003 | 07:24 PM
Ryan77's Avatar
Ryan77
The 255/60 is the same size sidewall as the 225/70 :confused:
Old Jun 8, 2003 | 07:42 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
I have 255/60VR15 on all four corners of my '77. I went with Pirelli Scorpion Zero's. No problem with rubbing and they look good on the car.
I have them on my stock Rally wheels :cool:
:seeya Jeff
Old Jun 8, 2003 | 07:43 PM
stpman's Avatar
stpman
Ryan77
The 1st number is the tread width in millimeters, the 2nd number is the sidewall height as a percentage of tread width
Steve :steering:
Old Jun 8, 2003 | 07:49 PM
Rockn-Roll's Avatar
Rockn-Roll
Take a look at my spreadsheet to see what tires are available: http://67.116.80.82/Vette/Files/TireRackTires2003.xls
I recommend the 245/50-15 Dunlop Sport 8000 for performance. But, if you want an economical long lasting tire that looks good then the BFGoodrich Radial T/A in a 255/60-15 is my choice.
Old Jun 9, 2003 | 04:02 PM
Ryan77's Avatar
Ryan77
Default Re: Need tire size suggestions....... (stpman)
Ryan77
Steve :steering:
:cool: The percentage was what I didn't understand, I thought that all 70 sidewall's were the same, etc. :cheers:
Old Jun 9, 2003 | 04:06 PM
Glutamine83's Avatar
Glutamine83
255/60/15's and they are yummy
can I put 275's on a stock 79 aluminum rim for the rear??
Old Jun 9, 2003 | 04:09 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Need tire size suggestions....... (shotgun_000)
A nice setup is also 255/60R15's in front and 275/60R15 in the rear... 255/60R15's all around look great too!!
Old Jun 9, 2003 | 04:10 PM
GrandSportC3
Default Re: Need tire size suggestions....... (Glutamine83)
That should work... I had 275/60R15's on my 69' (sold).. The tires came pretty close to the e-brake bracket.. but other than that - there were no problems...
To Need tire size suggestions.......
