IMPORTANT announcement for current Steeroids owners>>
Old Jun 17, 2003 | 08:16 AM
PureSilver's Avatar
PureSilver
Default Re: IMPORTANT announcement for current Steeroids owners>> (Speed Direct)
OK, what size group is needed and how do we go about soliciting sales??? :D
(I'd really like to get a Steeroids kit... :steering: )
Old Jun 18, 2003 | 05:28 PM
Speed Direct's Avatar
Speed Direct
Premium Supporting Vendor
Default Re: IMPORTANT announcement for current Steeroids owners>> (PureSilver)
Indy Year 25, I apologize for not answering sooner. All you will need is a pump and mounting brackets. We supply the hoses and everything else.
PureSilver, Last time we required a minimum of 10 orders to qualify for a group purchase. I can start another thread to see what kind of interest there is. It looks like we have 2 already so only 8 more to go. The GP deal last time worked out to $1018 total, including shipping. We set a flat rate for shipping and I think the price just for the system was $985. Overall the savings worked out to $173 or so.
Old Jun 19, 2003 | 07:35 PM
Indy Year 25's Avatar
Indy Year 25
Thanks for the response!
Have you posted yet? Did I miss it?
Old Jun 20, 2003 | 06:34 AM
69Myway's Avatar
69Myway
Eric and Speed Direct are great to work with.
I installed a rack on my buddies 71 in the last couple of months.
Within a week of the notice, the new bolts came.
It took two minutes to change them out and torque them down.
Old Jun 20, 2003 | 12:02 PM
Speed Direct
Default Re: IMPORTANT announcement for current Steeroids owners>> (Indy Year 25)
Indy, you didn't miss the GP thread. I just started it http://forums.corvetteforum.com/zero...781#1544338781
69myway, thanks for the kind words. You have an awesome looking Vette. Keep me updated on your progress with the electric headlight conversion.
[Modified by Speed Direct, 11:04 AM 6/20/2003]
Old Jul 2, 2003 | 12:10 AM
wallyknoch's Avatar
wallyknoch
What the hell is a steeroid? :)
Old Jul 2, 2003 | 03:57 PM
Speed Direct
Default Re: IMPORTANT announcement for current Steeroids owners>> (wallyknoch)
It's something that you must have for your car. Don't walk, RUN to you wallet and get your credit card. Call us as fast as you can and order a couple of them. You'll feel better.
Old Jul 2, 2003 | 04:59 PM
wallyknoch's Avatar
wallyknoch
No thanks, I already have muscles and I didn`t take steriods either. But I do need some black muffler bearings for my Vette. :lol:
Old Jul 6, 2003 | 09:13 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: IMPORTANT announcement for current Steeroids owners>> (NHvette)
How many of you have been running the rack without power steering pump assist?
Is it safe to do so? Will the rack wear out faster? Will the insides get hurt by a lack of lubrication?
Just thinking how much I would like to get rid of the PS system and go to a rack, but I want a rack designed to be used as a manual steering system.
Old Jul 10, 2003 | 11:03 AM
Speed Direct
Default Re: IMPORTANT announcement for current Steeroids owners>> (BSeery)
There is no problem with running the system manually. The rack gears themselves are lubed with grease (not power steering fluid) so there is no problem there. All the other parts, such as the servo valve, are tested upon reassembly so they will have fluid in them that will lubricate them just fine.
Old Jul 11, 2003 | 05:08 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
Which rack are you using? A GM J-car rack from the 80s? There should be plenty of them out there that are manual steer only. Might require a different setup for the intermediate shaft though.
Old Jul 11, 2003 | 05:28 PM
Speed Direct
Default Re: IMPORTANT announcement for current Steeroids owners>> (ddecart)
Yep, that's the rack we use but we spec. ours from newer cars because they have quicker ratios and better valving for the power assist. You are correct there should be a lot of manual racks out there and the pinion length will be the same because GM didn't want to re-engineer the steering column or intermediate shaft. I don't know what the ratio would be on a manual rack.
Old Jul 11, 2003 | 07:08 PM
  #33
ddecart's Avatar
ddecart
SPARTAN
CI-9 AutoX Winner
CI-3 Go Kart Champ
I can probably find out pretty easily what the ratios are for the manual vs. power rack. A manual rack should have a higher ratio than a power, just for the sake of mechanical advantage.
Changing the length of an intermediate shaft is a pretty easy affair. It's likely that there were 2 shafts released, one for power and one for manual.
Old Jul 14, 2003 | 11:51 AM
  #34
Blue80vette's Avatar
Blue80vette
Speed, I know this wasn't the intent of your post, but reading it caused me to look at your products and I just ordered a Steeroids setup for my Vette. Looking forward to putting it on very much!
Old Jul 14, 2003 | 12:29 PM
  #35
Speed Direct
Default Re: IMPORTANT announcement for current Steeroids owners>> (Blue80vette)
I'm glad to hear it, Blue80vette. You were even able to take advantage of our group purchase that is running right now for forum members. Thanks for the order!
Old Jul 22, 2003 | 10:50 AM
  #36
jonjollyf4's Avatar
jonjollyf4
:withstupid: Wow, that sux.. At least the manufacture is apparently using all communication channels to alleviate this dangerous situation.
Old Jul 26, 2003 | 12:43 AM
  #37
Dwayne 76's Avatar
Dwayne 76
Default Re: IMPORTANT announcement for current Steeroids owners>> (jonjollyf4)
Customer service is the best way to resale.
To IMPORTANT announcement for current Steeroids owners>>
Old Jul 27, 2003 | 01:02 AM
  #38
SharkByte's Avatar
SharkByte
Yipes, glad I checked the forum. I was going to start installing my Steeroids tomorrow and hadn't heard about this yet...
I guess I'll wait for the new bolts to arrive before I do the install...
[Modified by SharkByte, 3:06 PM 7/27/2003]
Old Jul 28, 2003 | 12:11 PM
  #39
Speed Direct
Default Re: IMPORTANT announcement for current Steeroids owners>> (SharkByte)
SharkByte, when did you purchase your kit? You should have already recieved the new bolts if your kit was affected in the service bulletin. If you measure your tierod bracket bolts they should be at least 80mm (3.15 in.) in length (measuring the shank, not the head). If they are 80mm or 85mm then you are fine but if they are 70mm then let us know and we'll get you longer bolts.
Old Aug 12, 2004 | 09:23 AM
  #40
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Originally Posted by Indy Year 25
I think I would be up for a group purchase. I just bought a 68 vert last weekend . I doesn't have power steering. Would I just have to add a pump and the Steeroid kit, or is there something else I would have to do?
You will need new brackets to mount the pump. If your car is a big block, you will need all new brackets (not sure about SB). You will also need a pulley. BB bracket kit is available from a few vendors (about $250?) and BB pulley is available (about $100).
