turn signal lever
Old Jun 9, 2003 | 01:35 PM
1slow78's Avatar
1slow78
Default turn signal lever
Hi everyone, does anyone know if you can replace the turn signal lever
w/cruise for the lever without the cruise control on a 78 with tilt/tele???
thanks
Old Jun 9, 2003 | 02:33 PM
Jim Shea's Avatar
Jim Shea
Default Re: turn signal lever (1slow78)
There is only one T&T steering column for 1979 Vettes. The assembly plant would install a lever w/ cruise or w/o cruise depending upon the options assigned to the car. The column didn't care. So there is a turn signal lever without cruise that is interchangeable with the one with cruise.
1978 through 82 levers are the same.
Zip Products lists: SC-333 78-82 Turn Signal Lever w/Tele, w/o cruise $16.50
[Modified by Jim Shea, 3:40 PM 6/9/2003]
Old Jun 9, 2003 | 03:33 PM
1slow78's Avatar
1slow78
Default Re: turn signal lever (Jim Shea)
that should save some $$$
thank you
:hurray:
To turn signal lever
